Old July 29th 2013, 10:10
Oval Oval is offline
amazing build...
aka VWCOOL
'68 Country Buggy.
'76 fuel injected Cabriolet
..and a good ol' Aussie V8
Old July 29th 2013, 13:26
dub_crazee's Avatar
that looks awesome
Classic Car Revivals
www.classiccarrevivals.com
Old July 31st 2013, 21:37
Picked this little guy up for the A/W intercooler rad. It's a stock 996/986 center rad, about $170 so I thought that was reasonable. Has about 3/4" inlet/outlet. Unfortunately I don't have any more room around the rad, so it's going to have to find a place somewhere else in the car...
Old August 20th 2013, 01:48
Getting there, working on the A/C system and getting the stuff under the hood to work out nicely...
Old August 24th 2013, 06:45
Rule09 Rule09 is offline
Nice!
Old August 24th 2013, 07:31
Awesome work!!!
Old August 24th 2013, 13:18
SuperRSi's Avatar
SuperRSi SuperRSi is offline
What a great build. I had considered this and your posts have convinced me not to! But Wow will you end up with a nice ride.
Old August 29th 2013, 00:21
Honestly, though having it in this state ads a bunch of extra ease for finish work, I would seriously consider just building a tube chassis and mounting all the components onto it next time. I like everything this chassis has to offer, but what a biotch to fit!!!
Old September 3rd 2013, 21:31
Back at it, just grinding through the details.
Fabbed up these steering column brackets, I now have a tilt AND telescoping steering wheel!!! This little bracket was a lot of work but now I can adjust the wheel for almost any seat or seating position. The nutsert tool is already paying for itself!
Finished up moving the clutch master over 1.75" as well. It's not what I would call pretty, but I'm working on my side under the dash so cut me a little slack. It is all sealed and if I ever do a renovation of this thing I can pretty it up then.
Steering column back in and we have steering again!!!
Finalized the angles, routing, and rotation of the tubes for the cooling system. I think Erik at norcalsandandoffroad got them welded up for me today. I do all the fiddley work and I let the pros do the talent stuff!
These are the details I'm most proud of, I was able to utilize the stock coolant pipe bracket even though my pathway is totally different.
Old September 4th 2013, 05:34
Fantastic work! Looks like things are getting a little tight now eh?
Old September 4th 2013, 11:51
graham's Avatar
graham graham is offline
Oval bugster
This build is just bonkers so much work
gee dub
Old September 4th 2013, 13:39
Hi Jason,
Good to see things progressing at a constant pace, nice to see the go-kart, must give some good motivation!
I might not be commenting much but rest assured I'm watching
Rich
Old September 9th 2013, 02:28
More coolant work. Had to "massage" the area above the front lower control arm attachment point to allow space for the rad. Not pretty but necessary. Also welded a tunnel through two body layers for lower rad hose.
This is where the tunnel exits, then up and over the rack bellows. Tight fit.
The top and bottom hoses join next to the gas tank. Also this is a high point for the lower tubing, so a bleed bung has been added that ties into the stock Boxster coolant bleeding system. Hopefully this makes for trouble free bleeding. Very excited to be able to use the factory coolant hose bracket!
The previously dual rad system now only has one pathway. Both side bleed tubes can be seen and will be used. On a technical note, I am now aware that there are special hose clamps for silicon hoses. They have an additional internal sleeve that offers a smooth surface for the silicon to be squeezed by.
I've been able to just squeeze this monster in there, next up add the A/C condenser...
Old September 9th 2013, 21:36
Coming along Jason. Very cool project!
Old September 17th 2013, 19:06
Small update, big progress.
I finally got the floor pan welded to the frame. It sounds simple enough, but the floor pan has a nice thick layer of German underbody sealer on it, and it all had to be ground back from the welded edge. A big mess. Then, to make it just a little more messy, I seam sealed the whole area. I forgot to get a pic, but I used a honey consistency seam sealer so I could really flow it into all the nooks and crannies. Trouble is I'm doing this upside down so I looked like I pigged out at the chocolate fountain...
Also got a jack point welded in, seen it the top part of this pic.
Anyway, here's a shot pre-sealer.
And a couple more of the rad area.
