#271
'56 rag with a twist
Very smart
gee dub |
#272
Thanks. This gives me more room for gearbox, engine and future plans
![]() Paul.
#273
Made the firewall a bit wider.
Wider piece it tacked in. ![]() The difference. ![]() fits pretty well ![]() Paul.
#274
Firewall starting to take shape. The first weld are made.
![]() ![]() Paul.
#275
Now we're flying.
![]() Time for the final things on the chassis.
#276
Looking good!
#277
Coming along nicely!
#278
Very nice build!
#279
Thanks guy's. The end is just a few welding wire roll's away
#280
The R&P was only temp tacked in place when the body was on. Back then I had to ditch the sway bar.
Today I welded the R&P brackets in its final place, made new brackets for the sway bar, mounted the sway bar and R&P and made brackets to mount the body to the chassis. ![]() ![]() Paul.
#281
Now the front is done, I started on the rear. The aligning is pretty good.
![]() Paul.
#282
Not much progress lately. I am supporting son's football matches more than working on the beetle.
Made 2 holes to weld the cage mounting points in. ![]() ![]() Dropped the body back on the pan and trial fitted the tubes that go to the gearbox. When these tubes fit properly I can start on the shock mounts. ![]() ![]() Paul.
#283
Very small update.
Made some extra room for the gearbox by inverting the bent. Trying it look original ![]() Paul.
#284
My route is not always the easy route.
Vwrankenstein's notch will be made of original sheet metal. Even to close the gab, of the shortened firewall, i am using modified original sheet metal. I hope that when it's finished this will give an original look. ![]() Paul.
#285
Looks good!
| Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
