Old June 26th 2016, 06:38
CraigRobbo CraigRobbo is offline
Out of interest is the colour p018 bluetorange?
Old June 26th 2016, 18:48
I was reluctant to straighten the shifter in case it was hardened and it broke, I didn't need to alter the shift rod length at all with my old chassis, I will need to extend it for this chassis, I was thinking of making an extension on the rear coupling.
where did you get the shift reduction kit from Wally?
the colour is Porsche 911 blood orange, not sure of the code
Old June 27th 2016, 06:48
hardened and it broke, ...
No, its just made of regular piss-steel
I'll look that up again, forgot, but somewhere in my old topic here...
Old June 27th 2016, 07:07
Thanks Wally, I saw them on the Wevo sight but they are bit expensive at $595 US but no doubt well made
Old June 27th 2016, 15:24
No, I haven't got a Wevo one. At Pelican parts they also have less expensive ones, just take a look there ;-)
Old August 11th 2016, 19:42
Panel work is finished, it will be painted next week, then I can get started on the chassis.
I'm going to fit an air intake in the right rear mudguard like Jak and Ricola have done, I will pass air through a BMC air filter box http://www.bmcairfilters.com/eng/ota...0-85l230-b/812... Im going to lift and turn my turbo so I dont have to run air under the inlet manifold and fit a V band housing to it
I've fitted a E85 Walbro fuel pump in place of the Bosch 044.
Old August 13th 2016, 09:21
Are you tempted to switch to a regular (non Subaru housing) turbo Steve seeing as you are re-making the pipework, I believe they are more efficient?
Old August 14th 2016, 03:53
Hi Rich
This is the rear housing I'm looking at, V band in and out http://www.vpw.com.au/Category/Index/390050
Started work on the chassis, I'm going to use 1 3/4 .95 roll cage tube for chassis forks etc. I'm buying a bender and notcher from these people http://www.affordablebender.com/coll...-tube-notchers
Old August 15th 2016, 02:03
Hi Rich
I was reading your website today, how are you finding your frozen boost intercooler?
Old August 16th 2016, 17:35
Seems OK and was cold to the touch when originally mapped, I have now fitted an IAT and also a wideband lambda and plan on doing some map fettling soon so will see from the logs...
New turbo housing looks good, I take it the new framehorns will have plenty of triangulation if only that size then?
Old September 7th 2016, 06:01
Hi Rich
Lots of bracing and I can double up on the tubes if needed.
been getting a bit done on the chassis. I'm going to lay my shocks a little further forwards to give more axle clearance.
I'm really happy with the tube bender and notcher that I bought from Affordable benders, really nice bend with no kinks. I made the first bit to go over the transmission and allow the torsion bar inner spline area to be removed.
I made an extra base for the hoop using 50x50 tube, I made it into a U channel and I was having difficulty cutting a hole with the notcher until I welded a length of angle to it
welded the hoop to torsion bar housing and added an extra bit at the base
Old September 12th 2016, 05:45
did the big cut today, no going back now
also did the cut out for the 944 spring plates
Old September 12th 2016, 15:28
Are you putting torsion bars in again? (not sure what else you are welding back in?)
Old September 12th 2016, 18:12
Hi Wally
m going to use the short 30 mm bars that I had in my old chassis again.
Old September 16th 2016, 01:29
Hi Wally
Ok, but why not going coil-over right away when you're doing that much work already? They say coil-over is a big upgrade over torsion bars
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
