Old November 12th 2006, 12:24
964 C2 calipers on a VW 412S. Pics inside
Since I know you guys hanging out here like brake upgrades, I wanted to post some pics of my - hopefully - succesfull rear disk brake upgrade:
Original trailing arm with 924T steel backing plate, bearing cover and handbrake shoes installed (bolt-on):
Turned-down (machined to smaller diameter to clear handbrake lever) original axle flange:
Fitment of 944 turbo disk and C2 caliper (it obviously needed a custom spacer):
Spacer/adapters made!:
Fitment on the car later....
Greets,
Walter
Old November 12th 2006, 15:14
Nice adapters Wally :agree: . Not many 412's over here though . I'm sure you will keep a typeIV in it though .
Old November 12th 2006, 16:14
Thanks,
Yes, that's the amazing part of it: It has a type 4 as the stock engine!
But it won't be a 'stock' type 4 4ever,combined with everday traffic with ABS equipped cars in front of me on the highways, I can use some more stopping power for the 18" rubber :
Old December 12th 2006, 11:02
Yesss!!
Upgrade has been succesfull:
Old December 12th 2006, 12:44
Great job Wally! Hey, those wheels are a different (silver instead of gold) color now. How many sets do you have?
Old December 12th 2006, 16:00
Thanks!
The golden ones were taken from my white 1303 because of a temp tire change
These are the dedicated 412 wheels
Old December 12th 2006, 21:08
yetibone's Avatar
yetibone yetibone is offline
Outstanding stuff Wally!
I'm not well versed in 411/412 original equipment. Are the original rear hubs, and brake drums like Type III parts, with a drum that's removable from the hub?
That's impressive how you engineered the spacers.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 13th 2006, 03:01
Yes, the rear drums of a 412 are in fact most all type III parts. All, but the rear hub. That unique rear hub is what neccesatated the complicated spacer.
I have long thought it wasn't possible to use 944 parts and not having to weld anything on the arms, but suddenly, on a bright moment, I got the right idea and a friend from a friend was able to make what I had in mind
After that it was a 'bolt-on'.
Old December 13th 2006, 19:46
yetibone's Avatar
Yep, I thought the hub and stub axle looked a little strange to me. Never seen a VW or Porsche hub without an axle nut before. Looks like the parking brake shoes will be easier to service with the hub machined that way as well.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
