Old March 6th 2007, 04:15
Angelo Amato's Avatar
Lightbulb wiring required for 944 rev counter
can anyone help?
cheers, Angelo
Type 3 Fastback
Old March 6th 2007, 04:22
One more thing...the tach from the '84 that I'm using is wired up as follows pin 4 GND
pin 5 +12
pin 6 coil -
Pin's 1-3 and H+, Hg not used
There you go, I tested it on my 914 and it works properly
http://www.germanlook.com/Forums/sho...ght=944+wiring
Type 3 Fastback
Old March 6th 2007, 16:00
1303R's Avatar
1303R 1303R is offline
on the back of my 944 rev counter i have three pins: +12, 1, -. +12 is ign live. 1 is coil negative. - is earth.
Old April 18th 2007, 03:14
rev counter wiring
help still needed.
The Fasty is now ALIVE and running
i tried above wiring that i stated but rev counter does not work.
got hold of the 944 wiring diagram off pelican parts but still cannot work it out.
1303R yours sounds the easiest ! is that an early 944 one then ???
to be honest, bought the rev counter used, i do not know if the rev counter works, but do they fail ??
cheers,
Angelo
Type 3 Fastback
Old April 22nd 2007, 13:46
1303R's Avatar
the one i have came out early dash type 944 and has a pointy glass cover, 924's of same age have same type to.
