Old July 14th 2007, 16:12
vwbao vwbao is offline
passat rack and pinion part number
hi, what is the passat rack and pinion part number that can be use for super beetle?thanks
Old July 15th 2007, 15:28
I'd be really surprised if a Passat rack will work properly on a Super. The distance between the pivot points on the end of the rack would have to be identical to the super to work properly. From what I've seen, Super racks are quite a bit different from modern racks.
Old July 15th 2007, 16:28
JIMP JIMP is offline
Hello Jason
the Pasat unit that I mentioned is not a modern rack, it's an 80's unit and reallity is that they are exactly the same at all aspects angles and dimensions except the drive shaft length (which can be shortened) and the way that is attached to the body (which also can be fixed). I cant post pictures so if you go to another thread called rack and pinion retrofit you'll see the pictures that vwbao uploaded and where it's obvius that they are identical. The only aspect that I hadn't time to check is their ratio, I suspect that the pAssat has more turns from side to side just to easy things because of the front placed engine and gearbox
Friendly
Dimitrios
Old July 15th 2007, 23:38
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Find a power steering one from an Audi 80 (in the USA called a 4000). It has fewer turn lock-to-lock.
Old July 16th 2007, 00:17
Originally Posted by JIMP View Post
Hello Jason
Friendly
Dimitrios
Thanks for the clarification! I actually have a 4000S Audi sitting in front of my house currently!
Old July 16th 2007, 03:54
AcyTom AcyTom is offline
http://www.blauparts.com/proddetail.asp?prod=L1B1004
Is this part correct?
I would like that you send some pictures of Passat part if you can!
Thanks!
Old July 16th 2007, 09:23
Thanks!
it looks the same,only its a power steering.
Old July 16th 2007, 10:09
the tie rods of the audi 4000 are located at the both ends of the rack not on the center. Here is the audi 5000/100/200 rack and pinion,I think this will fit for our application..,,??
5000 84-88
5000 Quattro 84-88
5000 Turbo 84-88
5000 Turbo Quattro 84-88
100 89-91
100 Quattro 89-91
200 89-91
200 Quattro 89-91
Will fit Automatic and 5 speed models
This information was given to me from an ebay seller.
Old July 16th 2007, 17:14
DORIGTT's Avatar
my 1987 Audi 4000 CS Quattro has the center mounted inner tie rod ends
Old July 16th 2007, 17:59
is your audi 4000 rack looks the same as the pictures above?thanks
Old July 16th 2007, 18:30
DORIGTT, please have a look. thanks.
Old July 16th 2007, 20:32
1302/1303 RHD steering rack on ebay:
http://cgi.ebay.co.uk/vw-beetle-1302...QQcmdZViewItem
Aircooled 4ever
1973 1303 going towards GL
Old July 17th 2007, 01:44
DORIGTT's Avatar
vwbao,
PM me your email address and I'll forward a pic from the service manual. If you look at the rack in representation to the parts around it you'll see that the close proximity of the centered tie rods to the brake booster would indicate it's centered. The 5000 series and above sure as heck had better have a beefier rack... that car is heavy.
True the 5000 and 4000 look different, but the 4000/VW Fox/Quantum still have tie rods that are equal length and the bracket that's missing from the illustration of the rack moves the mounting point of the inner tie rods over center of the vehicle.
I have a scan I'd like to post, but I can't get it below 1mb.
