Old September 11th 2007, 16:23
1303R's Avatar
1303R 1303R is offline
type4/wasserboxer clutch
can anyone give me an idea of how much power a 228mm flywheel/clutch can handle. i have a 1.9 turbo and the 215mm flywheel/clutch is slipping. i need something that can take 200~bhp. this is in a bug, daily driver so not light, cheers
Old September 11th 2007, 21:23
According to KEP http://www.kennedyeng.com/volks_pp.htm the stock 228mm setup holds 200 ft lbs.
Old September 12th 2007, 13:35
1303R's Avatar
cheers, now gotta work out if that gonna be enough. prob be on the limit. who's using a standard 228mm and running a lot of power?
