Old December 22nd 2007, 05:29
chug_A_bug's Avatar
hey thanks For Saving ME 140$ that is A Sweet Idea
thanks again
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old December 22nd 2007, 09:58
petevw's Avatar
petevw petevw is offline
Chris, post pics. I'll do the same for my panels.
'72 super
'65 bus
'52 split
Old December 25th 2007, 07:17
zeroaxe zeroaxe is offline
Originally Posted by FeralBug View Post
use the stock/factory clips, put them in the stock holes in the door, place some epoxy on the back of the clips, then align the panel into place.
once dried, the panel can be removed and replaced at ease just like the stock vw door panels.
doing it this way eliminates screw holes, giving a clean appearance.
this is how i did it, works perfectly. i hope this is useful.
This actually sounds like a REALY good idea! I am just wondering what you will do if a clip actually BROKE!? I suppose you can put a sander to it and sand it off flush with the panel, and then re-epoxy another one in place. So not bad at all!
Zeroaxe
Old December 25th 2007, 16:19
chug_A_bug's Avatar
hey Pete Ya I'll get Pics for ya I'll Be doing it Later this Week
HEY got Some time to do abit on the Panels here's some pics
chris.
74 Std. GL
08 Vw rabbit
18 WR250R
Old December 31st 2007, 22:19
chug_A_bug's Avatar
all I did was Measure where each pin was and re-marked it on the back Side of them
then I was just going to take side cutter and cut off the back of the pin so it will sit Flat
and I'm just using super Steel epoxy from Lepage just got it at Crappy tire.
74 Std. GL
08 Vw rabbit
18 WR250R
