Old February 3rd 2008, 04:52
old gh bug old gh bug is offline
901 clutch fork problem
Hi i have just installed my 901 box and trying to set up the clutch cable
whilst trying to fit the thrust race bearing to the fork i have come across a problem it appears that the pivot ball that it sits in is in a difference place on my lever
the quetion that i am asking is are there different sizes of lever arm for the 901 box or am i just doing something totally wrong i am not sure if this one came with the box
I hope this makes sense and someone can help me on this problem
Thanks Garry
Are there a couple of different ones for other 901 boxes does anyone know
Last edited by old gh bug; February 4th 2008 at 16:22. Reason: more info wrong title
Old February 4th 2008, 16:23
someone must know or may be have a spare
Old February 4th 2008, 22:21
Bug@5speed(US)'s Avatar
Old bug, Can you take a pic of the back side, and email it to me, or host it..
Bugat5speed@yahoo.com
If you have the wrong one, I may have spare, but will need to check.
Will check for you
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old February 5th 2008, 07:00
Here are couple of pics of the problem i have
Any help much appreciated
Old February 6th 2008, 03:53
Hi,
it seems that the tranny that you have might be a 911/01. This type normally has a pulled type clutch and itīs fork sits in a different place. The lever you have is from an old 901-gearbox. The 901 and 914-levers are very similiar. The position of the ball is the same, but the position of the drill for the bolt is different (but that makes no difference). Please identify your gearbox by giving us the ID of it. You can find it underneath the gearbox stamped into the housing (at the lowest point of the gearbox). Must be something like 911/01 or a figure like 901/13.
If you have a 911/01 you have to replace the position of the ball in the lever by welding in some metal and then milling in a new position.
Hope to have helped
Martin
Bug @ 5 Speed
Old February 8th 2008, 08:51
Thanks for your help looks like i am going to have to get the drill out unless i can get a nothe clutch fork
Old February 9th 2008, 12:38
Originally Posted by Bugat5speed View Post
Hi,
Hope to have helped
Martin
Bug @ 5 Speed
Hi Martin
The stamping on the bottom of the box is 911 / 01 and also 7700755 don't know if they mean anything to you , if you had a fork to fit this how much would you want for it thanks
garry
Old February 9th 2008, 13:42
Yep,
That's a 1970+ 911 gearbox, as Martin figured.
If he has one, he will let you know
VR
ALex
Alex Olaverri
Tele: 973 204-5463
Old February 9th 2008, 14:35
Hi,
have got no levers in stock for such a conversion. Mostly old 901 or 914 gearboxes are used and that are the levers I normally have in stock.
So I think you have to mill a little.
Sorry that I canīt help you
Martin
Old February 10th 2008, 05:30
Thanks for all your help and identifying what i need
Best regards Garry
