Old September 29th 2007, 09:01
A steel hub is way more heavy than the porsche alu hub is.
Low non-suspended weight all the way for me.
Old September 30th 2007, 17:52
jamesbissland jamesbissland is offline
for the difference in weight wally, you should just stop eating as many pies
Old October 1st 2007, 16:17
andy1303 andy1303 is offline
The interesting thing about this hub is it will allow stock PCD wheels, which the porsche hubs will not.
Old October 2nd 2007, 05:22
AND use std bearings, and not have to worry about machining etc etc :agree:
Old January 29th 2008, 10:13
mabbo mabbo is offline
if i used the pacific customs hub, bolted a 944 disk to the back, and used a 944 caliper with caliper bracket... i could use 4x130 vw wheels?
Old January 29th 2008, 11:34
fuzzybear1981 fuzzybear1981 is offline
this is what i was thinking but someone told me that it wouldnt work. I have a set of 5 stud porsche drilled beetle discs that i was going to get machined. What disc will will i be able to use over this hub? will the hub need to be machined down and will a 944T 1986 caliper work?? HELP ME...thanks
Old January 29th 2008, 13:58
DORIGTT's Avatar
DORIGTT DORIGTT is offline
I would think you would get a disc/rotor that you want to use and have the machine shop 'make it work'.
Old April 21st 2008, 00:19
alikatcraig alikatcraig is offline
My '98 has them as do later ones, so '98 to 2004 would be a safe bet.
Al
Old May 1st 2008, 19:57
Mr Big Mr Big is offline
This is exactly what I've done. I wanted to use Porsche brakes on my bug, but the wheels I have are 5 x 108 pcd. You can't redrill 4 x 130 hubs to run 5 x 108 because the holes interfere, nor can you redrill 5 x 130. So I had to buy blank (vented) discs and turn them down to use as hubs. Then spend a lot of time running through the parts catalogue to find 300mm discs with the same thickness and the right pcd. Loads of fun.
But at least the rear was cheaper......Porsche 924 discs....same as bug ones but with 4 x 108pcd. Redrilled to 5 x 108 and im ready to go.
Next time im using porsche stud pattern!!!!
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
Old May 31st 2020, 04:53
Looking for information on Porsche brakes and I came across this old post that I made.
I'm resurrecting the Porsche brakes that I ran on my 1302 and then later on my 1303 for a while for my sons 1303. I've had them converted to 114.3 stud pattern as my son wants to run Jap wheels.
Anyway I did eventually do what I proposed in this post with 944 hubs and an adaptor bracket. 944 grease caps even come with a speedo cable drive hole
Old June 2nd 2020, 15:14
Nice adapters! Who made those?
I run the 944 grease caps as well on the notch: works well with the stock VW speedo indeed!
Old June 3rd 2020, 18:47
Thanks Wally, a friend of mine Dave Stocker from LMS engineering who was a retired tool maker made them for me, he made lots of things for me including all the machine work on my sons oxy boxer, he also built a tube chassis drag car. Sadly he passed away earlier this year with lung complications from our bush fires
Old June 7th 2020, 14:20
Thats sad news Steve.. sorry to hear.
Lanner did mine for the notch. CU
Old June 7th 2020, 17:48
effvee effvee is offline
Hello,
Is Lanner still around? He once had a wed site, does it exists still?
Old June 7th 2020, 23:00
flat flat is offline
I'm still kicking! Lol
Vdubengineering.com
www.vdubengineering.com
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
