Rear coilovers on supers
I have maxx struts on the front and wanted to install the rear coil over kit. Does anyone know who would have the best quality kit out there. i have found several kits but i haven't really found the actually coilover shocks. Just the adapter kit.
Loads of companies sell coil-overs, AVO, Spax, Protech, Bilstein etc etc, we are spoiled for choice in the UK! Just measure up to see what you need. Personally I will (and have before) be going for protechs...
http://www.ricola.co.uk |
I've gone for Spax on the rear in anticipation of adding a threaded sleeve for coil overs. However, I will be retaining the torsion bars as well using the coils just to up the overall spring rate. I would be very nervous about relying on the 12mm bolt at the top and the aluminium housing at the bottom to withstand the stress of providing the fixing for 500lb/in + springs. Remember that the bolts are in cantilever bending that creates a moment that is around 4 times that of a bolt suspended between two fixing points. I can't see any good reason unless of course you would require a full progressive spring rate instead of the linear one that was imparted by the torsion bar.
evilC |
can we get a bunch of various coil setups in reference pics explaining the various differences / pros & cons? the gallery isnt that great at explaining the variences between each, just a thought
1971 Superbeetle, stripping the old stuff, getting ready for paint, then bolting on all my goodies, sorting problems by ones self is a challenge it seems, any GL beetle people in Brisbane say hi! Its been 3yrs since i drove my dub
I posted some over here, it's in Dutch though
http://www.keversite.nl/forum/viewtopic.php?f=5&t=16351 (Achterkant = rear) Is it for steel trailing arms or for 944 Alu trailing arms? About the single shear: It's a good point, but in the Käfercup they raced with the single-shear setup and it didn't break. And they did push their cars to the limit. |
the lower mount on a steel arm is actually much better than the alloy arm because the bolt is only in shear, which it can cope with very easily. The alloy arm however, uses a 14mm bolt again in cantilever, this time with a substantial lever arm as the threads are well buried in the housing. Remember, both VW and Porsche designed these fixings only to take damper loads that are minimal compared to the loads imparted by a spring. evilC |
evilC |
Sorry, my post was inclomplete again, I ment single shear on the trailing arm, since the upper mount can be made into a double shear mount.
Anway, thanks for your answer! Why does the bolt in the alloy arms work in cantilever (and why doesn't it with the stock arms?) Is the damper under a different angle compared to the stock arm? And only the topmount is of concern, since it's the one that gets a bending load? Last edited by Simon; September 8th 2008 at 13:06. |
The bending load is in both bolts equally but the bottom bolt of the alloy arm is M14 and the top bolt is M12 a difference of 36% in bolt strength but the M14 is a longer bolt and therefore the bending moment is greater (PL/4). evilC |
the mo30, 951 ALLOY ARM, USES A COIL OVER SHOCK, WITH THE TORSION BARS
I completely agree and it's why I will stay with the torsion bar set-up.
hello 951 - m030 option
Yes, but what else did Porsche do besides just bolt that "shock" on there? What other modifications were made, in support, of the M030 option?
it tells you on that link
-fat bars adjustable koni's there isn't much else you could do is there? |
