Old July 2nd 2010, 08:29
Tnx Ninja,
Originally Posted by paul_f View Post
Where do you take your MAP from Wally, have you drilled and tapped the manifolds?
Cheers
Paul
Yes, tapped all 4 ports and have them come together in one box with some more fittings for MAP sensor, waste-gate, EBC, BOV and fpr. 9 connections in all therefore...
Old July 3rd 2010, 06:36
Now I know what I wanted to ask you Wally..where did get those thick gaskets for your manifolds and throttlebodies?
Old July 3rd 2010, 07:36
Those were made (machined) from hard plastic 18mm kitchen top material by a friend of mine.
Mc Gyver style
Old July 3rd 2010, 09:00
Really?! That´s pretty cool! I would have never thought of that! I hope your wife wasn´t too hard on you for cutting a chunk out her kitchen top
Old July 3rd 2010, 09:10
Great upgrades Wally. All appropriate for a 400 hp " 20 min Ring " beetle
Old July 10th 2010, 05:01
Finally I got all parts to install the Sard FPR:
Tnx Sandeep; spring 2010 is already behind us, how is your engine comming along?
Old July 10th 2010, 12:45
Cool! What did set your fuel pressure at? Will you have change your maps or can the DTA adapt and still use the current maps?
Old July 10th 2010, 12:53
paul_f's Avatar
paul_f paul_f is offline
Wally will you leave you fuel pressure gauge in place or will you remove it?
I have the same one, but it says to only use it for setup only and to not drive with it fitted on the box
Old July 10th 2010, 14:33
Mark: it was about 3,5 bar, but the closed loop fuel control of the DTA ecu can easily make little fuel changes if fuel presure will be different
Yep, the same text was on this one. The gauge was very cheap, that FPR wasn't
Not sure yet if I will try it out on longer runs, but I might just remove it and plug the hole after the fuel pressure is original again.
Good eye!
Machined flywheel for the twin disk set-up just before it went in:
Old July 14th 2010, 13:40
Reinstalling engine pics:
I wanted to connect a port from the header to measure turbo beack pressure. From am idea of a good friend of mine, I used an old brake hose to saw off the coupling and just used a regular copper-alloy brake line to connect it to:
Old July 14th 2010, 16:29
chug_A_bug's Avatar
looks great as always man... btw your dog is Sweet looking
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old July 14th 2010, 16:34
Pablo Pablo is offline
I see a new addition. Have you had trouble with the fan belt jumping off Walter?
Paul
Old July 14th 2010, 17:54
Paul
Good eye Paul. Yeah, it ran fine for two years beating the sh*t out of the engine revving to over 7K, but at the last drag days this year, the belt suddenly came off, mainly in the burn-out box when the rear suspension bogged/squatted.
Hopefully this will keep it on, even in 'abnormal' conditions.
Yep, love my english springer spaniel. We have always had those for as long as I can remember ;-)
Engine runs again and the twin disk seems to engage pretty easy and gentle. Much to my surprise I must admit. It only rattles from the center plate like an old Ducati when the clutch is depressed. Oh, well
Tomorrow test drive to work I was thinking
Old July 18th 2010, 06:41
Test drive went fine: clutch engages really not different than the former one, which is great!
Backpressure is about 50% over boost pressure, which gives great spool but seems a little too restrictive for this 2.2 liter engine.
I need a bigger turbo! (again..)
Next weekend is Spa Francorchamp 'Le Bug show'! Can't wait to finally be allowed to drive the whole track.
Old July 18th 2010, 08:14
Good to see you have overcome the clutch issue. That set up should get the power down. Have a good trip to Spa. I hope to see an in-car video of a lap of Spa.
Currently Active Users Viewing This Thread: 30 (0 members and 30 guests)
