'56 rag with a twist
After lurking here for a while, time to post some pica's of my project.
I am not sure what it is exactly, is it german, resto, callook or race? you tell me ![]() It all started in December 2007, after I sold my T2a single cab with 190Bhp G60 engine I bought this Oval. The plan was to use it as a daily and give it some TLC in de weekends. This is how I bought it, original. ![]() Planted a new gearbox and 2ltr type4 engine. ![]() Narrowed, adjustable beem with dropped spindels. ![]() And this is how I drove it (first time out was EBI II) ![]() To make a long story short, it's a total resto now. The plan is to have the resto-cal ish look on the outside, with an inside, chassis and suspension that is ready for some strip and circuit aktion. Let's start with the wheels; I have two sets, fuch's and MAG industries, both with Porsche bolt patern. One set for street use and one set for circuit/strip abuse. ![]() ![]() Paul
If some is good and more is better, then too much should be just about right! Last edited by fahrvergnugen; October 1st 2010 at 16:07. |
The front suspension;
Porsche 914/911 with 944 hubs and disks. ![]() ![]() Test fit.
Rear Suspension;
18cm narrowed to have the same width as an original oval. IRS with 944 arms and brakes. ![]()
Gearbox; 914 dogleg, raised with homemade mounting points.
The "kill switch" I named it the "O ****" knob.
Now I am working on the body.
Most of the rust on the right side is gone. ![]() The complete doorpillar is gone. ![]() And replaced. ![]() ![]() And today I was working on the 1/4 panel.
Almost ready, after using some lead filler it looks like new again 8)
For an oval they even don't sell the bad fitting repro sheet metal. The only thing I could do is restore the old metal.
Together with some Tikimadness leftovers :thumbsup: (drag race oval) I will try to fix it again. ![]() ![]() With these 2 holes the body is mounted to the torsion tube. My torsion tube is about 9cm narrowed (each side) so these holes needs to be moved. ![]() ![]() ![]() ![]() Here's the difference;
The original form was long gone, so I had downloaded some pictures and started moddeling metal.
![]() ![]() ![]() It's a corner you can't see when the car is ready, but I like it to look original.
Finally finished the left corner. When the body is back on the channels I will cut the corners at the wright lenght.
![]() ![]() Nice fit, only have to grind the welds down and use some lead to smooth things. ![]() ![]() On to the right site.
Found some pics of the custom rear suspension;
![]() ![]() ![]() ![]() ![]() Paul
daaamn! nice project! I always said the Netherland and especially Keversite.nl has the most GL projects going on. Too bad of the language barrier, so thanks for posting here, in english! I often read through the Keversite forums with the help of google translate :P
www.vw1303s.com |
Oh man, you are up to your eyeballs with that project!!! Great work, can't wait to follow the progress.
You and Ricola need to get together and have a beer discussing how many Km of welding wire you used on your projects!!! Jason
looks great loving the front suspension
![]() cheers andy |
Good to see you have made progress since I last looked at your main thread! One thing I'm not sure about is the inner bit of your spherical bearing mount. It looks like you have a rigid outer (hole in steel plate) and a urethane surrounded inner mount, this will lead to movement and potential fatigue in the bolt. I think if you just made the inner part rigid it would be good (much better than a lot of other kits that use loose outer plates...
Rich
http://www.ricola.co.uk |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
