#601
My turbo location is already rather far away, so I will do anything fysically possible to keep pipe lengths to a minimum, hence this construction/lay-out
#603
Yeah,I hear ya Wally - space is a big problem.I´m hoping my GT3071R will fit in your old location.I won´t find out until I have the engine in the car.Hopefully my case will finally be back on friday so I can put it together.I will be putting the car together this winter -finally.
#604
Winter time is the best for car projects!
VW 1303s 1975 (German Look) VW 1300 1964 (Rally Car) LAND ROVER DEFENDER 90 V8 BMW E30 318i CONVERTIBLE 1992 Italian Toys - GERMAN WAR MACHINES ![]() WRC is for boys - GROUP B WAS FOR MEN |
#605
Yeah,finding time and motivation can be tough.Thanks to threads like this it keeps the fire going.So if my car never gets finished it´s Wally´s fault for not posting enough videos and pics
#606
Wally we need more videos, pictures, everything you have to keep us going!!!!!!!!!!!
#607
Haha! well, not spectaculair news, but some small steps are sometimes needed as well to complete a job.
So, I now finally have the oil feed for the Borg turbo complete ![]() This was quite a hassle. Why? see for yourself: ![]() ![]() Left to right: 1/4" NPT is the thread size into the turbo, so I needed a 1/4" NPT to 1/8"NPT adapter, 1/8"NPT male to 1/8"NPT with 0.165" restrictor (1.5mm), 1/8"NPT to inverted flare female connection and M10x1.0 inner thread, M10x1.0 male and inverted flare 'copper' 5mm (~3/16") brake line. This connects then to a goodyear braided oil line (with M10x1.0 ends) that feeds of the oil pressure connection on the engine case (with a 'T' for a oil pressure sensor) Next job will be the oil drainage adapter, which will have to be made from scratch (from hi-grade alu) for my -12 line... (all adapters for sale are -10...) |
#608
Why the 1.5mm restrictor?
#609
Folder! This is almost like a masters class.
#610
1.5mm or AN3 line feed.
Its prescription from Airwerks Borg-Warner. Same as large frame Garrett non-ball bearing turbo's
#611
Learn something new everyday! So this one isn´t ball bearing either?
#612
The twin-scroll should provide the quicker spooling. When tuned right (header sizes), these spool as 'fast' as a Garrett 35R does with a little more hp under the curve, but for less then 2/3 the Garrett BB price tag
#613
If you have the same spooling time as with the old turbo but more power and ability to keep the boost level in the high rpm aswell, then it was worth it imo.The BB turbos are nice,but like you said so much more expensive.You would have to ask yourself if the advantages of the BB outweigh the price tag.
#614
I am sure spool is much later now, as this is a TOO large of a turbo for this engine/application. A comparable BB turbo of this size would also have later spool, but like I said before: this turbo was NOT ment for this engine, but a much larger one ![]() Still I am very curieus what this will do on this 2.2 engine as I have so much data on this engine already. Only if you look at a drag racing application, this turbo could do well if the cam could support the flow/rpm. For pure drag racing, the cam is not optimal either though.. As always, its a big compromise as it is. It is tempting to completely disassemble the engine and do a cam swap, just to give it drag racing caracteristics and really let it rip at the strip ![]() Not for now anyways, I have a hard time thinking how to install this turbo as it is
#615
When is enough?
![]() Quote:
Hi Walter, I have noted your up-grades and congrats. Question, when is enough on your current engine, before you have a major failure? You have done very well, I'd hate to see you engine let loose .
| Currently Active Users Viewing This Thread: 34 (0 members and 34 guests) | |
