#736
Hope that will make things more clearly? Quote:
Hope this helps a bit? |
#737
How were your temps and afr at 1.9 bar?
#738
I'm curious to see temps too and turbo response at lower rpms 3k-4.5k (when it starts spooling to max boost). I have to remember to read your logs right to left (backwards btw
) is that a "feature" or an option with your ecu?Other than that it looks good, you've got me looking at the bw turbos now, specifically the EFR 8374 with a 87mm turbine and .90 a/r for my 2165cc @ 25psi (current boost limit w/o intercooling). |
#739
Dude! What do you think is going on in a bug at 1.9 bar boost and 5K rpm on a public highway (german Autobahn)?
I was lucky to check the boost gauge and notice that too high setting at all , let alone watch other gauges ![]() The log direction is stock and non changable...It constantly adds log info to the left, so everything shifts to the right as the log info builds. Its not that strange if your used to it I guess I agree, the new high tech BW EFR (engineered for racing) turbo's are the shiznizz! The EFR 8374 would have been my choise as well. Pity the twin-scroll version is not due untill a few months, so we have to wait for real-life results. I think the ultimate hp that that one supports might be close to mine. So, its plenty probably
#740
Wally,
With your DTA are you running it with MAP as the load for the main fuelling/ignition maps or TPS with MAP multiplication? Cheers Paul |
#741
Paul,
I have only ever ran TPS. Now with the turbo motor I use an additional map-sensor for fuel and timing compensation when under boost. |
#742
Thanks for that!
A friend is switching from an E48 to a S60 on his turbo bug and is currently using TPS and were weren't sure whether to switch to MAP as load instead of TPS. We will stay with TPS |
#743
Or is that not recorded? You must overcome your fears young Padawan and drive on the autobahn every day..
#744
Ah! No, those temps are both measured with a thermocouple and the ecu doesn't have the ability to register those. Unless you have an expensive adapter box...
Today was a dyno day, but on the way there, I had almost no boost anymore. Engine runs very well, but no boost I checked and even removed parts of the intake and downpipe (turbo spins fine, no play), but couldn't find a leak or anything, so I returned home. Still no clue as what the cause is. |
#745
I wondered about the machining on the turbine space, the gap around the wheel. Is it possible that one of the faces needs to be machined more to tighten up the seal around the wheel?
I am not a turbo guy per se, but it looked like you just added a larger housing to your existing piece, and I wondered if maybe they needed to be matched somehow? Lame question, but I think you might understand what I'm thinking. It's not like you to do something wrong, and the engine still runs so it's not like you left a rag in there or something, but low boost could be that the air is not being channeled well around the turbine wheel to create boost? Just a thought. Jason
#746
I understand your question and its a very valid one. This extra turbine house is however meant for a small series of same-size frames.
Most turbo's can be ordered with a variety of turbine A/R's so they all have the same 'form' so to speak. After some wrenching today it turned out I had an exhaust leak from the complex part where I made the twin exits into one for the wastegate. I have welded most of it shut now (saw some black traces) and had full boost again Not the same respons I had on my trip with this housing to germany last week, but close enough. Maybe I missed a spot, will have to look lateron some more into it.Pfft.. |
#747
Specially for Sandeep, my compensation for removing one side of the Cupstrebe as it was in the way of the turbo (inlet):
#748
Glad to hear it wasn't a problem with your turbo. It's strange that you had no boost though, sounds like that leak was not that small?
#749
Luck and badluck all in one...
This was the perpertrader that made he resonance and had the turbo spool 250 rpm later then before: A piece of the divertor wall I had welded in there broken off and got loose: ![]() Turbo wheel looks fine and not hit ops:
#750
that was a lucky escape, not worth thinking about the damage it could of cuased.
| Currently Active Users Viewing This Thread: 24 (0 members and 24 guests) | |
