Old October 14th 2014, 02:39
-Alex- -Alex- is offline
Looks fantastic Good to see that all germanlook beetles aren't 1303's
Old October 14th 2014, 13:49
Gerrelt's Avatar
Gerrelt Gerrelt is offline
Beautiful beetle!
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old October 14th 2014, 15:42
Bogara_ZO's Avatar
Thank you guys, your builds here inspired me a lot!
It's time for detailing:
Ignore the rubber fuel lines, braided hose with AN fittings are part of the winter project.
Old October 14th 2014, 18:36
Love this car, such a great combination
Old October 16th 2014, 15:12
Bogara_ZO's Avatar
Hopefully the last time on the trailer, arrived home today!
Old October 17th 2014, 20:02
Nice tow rig
Old October 20th 2014, 03:43
Bogara_ZO's Avatar
After 3 years, yesterday I finally drove it! Engine sounds good, brake and suspension feel ok, no oil leaks so I'm happy with it.
https://www.youtube.com/watch?v=tPhbUWnfvUE
Old October 20th 2014, 14:55
Stevo_L's Avatar
Stevo_L Stevo_L is offline
nice looking 1302.
back is a little too low for my taste.
german-ghia.blogspot.com
Old October 21st 2014, 02:50
bugpilot bugpilot is offline
She's a beauty...
Definitely a huge motivation to get my little red bug back on the street again!
Greetings,
Tobi
Old October 21st 2014, 20:03
Clatter Clatter is offline
Just Beautiful...
A style of build user 'vujade' coined - "Resto German".
Subtle, understated, OG in the details...
Love it!
The ride height/stance is perfect.
Rake is for Cal-Lookers.
Old October 21st 2014, 20:04
Oh, and, can you explain the oil pressure gauge fitting?
Old October 22nd 2014, 09:32
Bogara_ZO's Avatar
Thanks for the comments, guys!
Sure it's temporary solution
I'm trying to keep the dash simple, so originally inteded to make a nice custom bracket for the rearview mirror and put these gauges there, similar to this:
I did the wiring too, but the wire harness seems to be too wide to make it invisible..at least need more time for that project. I wanted to drive the car ASAP and found a gauge holder in the garage that doesn't fit in the radio area. Again, I'm sure I will not put them there as I'm not a fan of the space shuttle style dashes. Will cover the hole with a c/f plate or similar and try to find a good place for the gauges. (Maybe under the dash?)
Regarding the stance the back is a tad lower than I wanted (hard to set the TB bars without the full interior). I'll see how it performs in city driving & on speed bumps than will raise a spline later if needed. But no rake at all.
Old October 22nd 2014, 15:45
H2OSB H2OSB is offline
I love the way it looks! As SteveC said, the color combo is excellent. Personally, I like the rear exactly as it sits. Unless it causes problems, I would probably bring the front down ever so slightly to match the rear.
johnL (aka H2OSB)
Old October 23rd 2014, 06:17
Bogara_ZO's Avatar
Thanks! Exactly, but a proper wheel alignment should be done first. Negative camber in front should help fender clearence, so i guess it can go lower a bit.
Old October 24th 2014, 02:42
graham's Avatar
graham graham is offline
SleepAIR Build Thread
Great looking car man,colour wheel combo is class
gee dub
