Old May 25th 2019, 05:12
josvandegalaxy's Avatar
josvandegalaxy josvandegalaxy is offline
chassis fitting everything one last time before cleaning painting and last time placing...
Old July 27th 2023, 09:33
this was our bug in 2019, with the 1641cc engine
this was 2021 but still some struggles withe the 901 gearbox and the 2.8 type 4 combination
and this was this year on Clastres, finally without mechanic problems
Old July 31st 2023, 13:55
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What struggles were you having with that 901 gearbox?
Old July 31st 2023, 13:56
DORIGTT's Avatar
What's the fuel capacity of this tank?
How much taller than standard is this tank?
Originally Posted by josvandegalaxy View Post
teardown
There was a very big tank in it
Old August 9th 2023, 06:38
Great update! Tell us more about the 2,8 ltr Type4 pls :-)
Old August 16th 2023, 13:25
it was a 70 liter tank, homemade back in the day.
the problems with the gearbox, it wasn't only the gearbox, it was the gearbox and the combination of the used parts.
- The 215mm flywheel dindn't have the bearing, so we got the flywheel machined and that was a problem solved
- once the gearbox became hot, there was an oil leak. the modified nose (also previous owner) was leaking, and you don't want that on a racetrack, so we bought another nose, had to modify it a bit. another problem solved (we tought). But apparently the gears were damaged by the heat.
So, another gearbox, the case from a 914 is the same, so... But we forget to change the breather hole (stupid, I know) so once you drive a few minutes in high revs, he throws out the oil.
But for now it runs great. Maybe we'll be at Le Bug Show next weekend
Old August 16th 2023, 13:47
82mm stoke Scat crankshaft met 104mm JE pistons and cilinders so a 2782cc to be correct.
billet Thorsten Pieper heads with type1 exhaust ports (CSP python 48mm)
322° camshaft. for now still the standard type4 rockers and 48 idf carbs.
good for 207 bhp and 280 Nm on the wheels.
