Old March 14th 2003, 10:34
karmann72 karmann72 is offline
86 944 trailing arms on a Ghia
I am looking a a set of 86 944 alloy trailing arms with disc brakes for my 72 Ghia and am wondering if the track will be pushed out too far. I am guessing that I will have to use a high offset wheel (porsche C2?) but would like to know if anyone has any experience or opinions on this?
Old March 14th 2003, 11:34
Hiya,
With 86 alloy arms your width per side will increase by 22mm, same as stock IRS arms with the early 944 NA ebrake components. The advantage to the early arms is weight savings but I am unsure of how much.
I don't have any experience with ghias but there are members here who do.
Hope this helps.
Old March 17th 2003, 22:31
SprintStar's Avatar
SprintStar SprintStar is offline
Originally posted by Sandeep
Hiya,
Does this mean that with 86 alloy arms and 944 brakes, my increase in track is still limited to 22mm? If so, I'm going to jump for joy!!!! That's one question I've been burning to ask but never got to...
Hehe...
Sprint.
Old April 21st 2003, 10:11
Bump
Old April 21st 2003, 10:46
Humble's Avatar
Humble Humble is offline
I just did the '86 944 aluminum trailing arm swap on my bug, and the difference is more than 22mm. it's more like 74mm. i'm not sure if even c2's would work with this setup under a ghia, either way it would be very close. the rear hub face on my beetle is 1-2" from the outer edge of the fender as you look at it from behind.
also i'm not sure what the back spacing is on c2's but if it's more than 6" it'll be a tight fit.
Old April 21st 2003, 11:46
Alex's Avatar
Alex Alex is offline
Humble,
are you sure you have 86 AL arms and not 87 and later ones?
74mm track increase per side sounds like 87 and later ones to me.
Old April 21st 2003, 15:57
Stuart Stuart is offline
74 mm is for 87 and later 944!!!
Old April 21st 2003, 20:47
Humble's Avatar
the trailing arms i have came off an 86. they're aluminum, and required 21" axles. they are the 74mm increase arms.
i thought all the aluminum arms increased the track 74mm, and only the earlier steel arms increased by 22mm.
Old April 22nd 2003, 13:00
Post
The 86 AL arms have a 22mm increase per side. If you take stock beetle arms and add the bolt on 944 N/A brakes, they will increase the width by 22mm also.
This has been measured and verified when I helped Alex out with his floorpan a while back. He has the 86 AL arms, and I have the stock beetle arms with 944 N/A brakes. Both increase the width by 22mm each side.
Old April 22nd 2003, 21:10
SprintStar's Avatar
Hello Sandeep,
I have a '73 Super with stock Beetle arms and 944 N/A brakes. Yes, I have 22mm increase in track on each side.
How, if I switch the Beetle arms for '86 AL arms, will my track increase or remain the same? Of coz I'll be using the same 944 N/A brakes.
And if I put on the 944 Turbo brakes? I don't expect the track to increase much as the caliper mounting is the same and the rotor is only 2mm wider?
Thanks for any input! I've been meaning to get '86 AL arms on, but I'm afraid of the width increase....
Sprint.
Old April 23rd 2003, 09:24
Post
From the measurements I have taken, the width increase should be the same. You can swap the beetle arms for the 86 AL arms and you should have no increase in trace width with the 944 N/A brakes.
With the Turbo brakes you should not have any further increase with the AL arms. Its the disk thickness that is 24mm for the rear and the part of the rotor that mates to the hub should be the same thickness as the 944 N/A rotor so you should be good to go.
I will be doing this same swap winter 2003.
Old July 25th 2003, 18:04
Bugnutz's Avatar
Bugnutz Bugnutz is offline
Same here
Humble-
It would seem that all 1986 944 aluminum trailing arms are not created equal. I have a pair from an '86 and they are also the wide track.
Regards, Mark.
Old July 30th 2003, 11:45
MattKab's Avatar
MattKab MattKab is offline
The '86 Aluminium arms when fitted to my '03 gave a track increase each side.
The '86 steel arms gave the same track increase.
I have a pair of each.
As I posted before (sorry to repeat) the hubs that came with the '86 ali arms are the same as those that came with the '86 steel arms. The discs were the same also.
However, the hubs that came with the steel arms had longer studs and a 21.5mm spacer between the disc and roadwheel.
I fitted the 944 steel arms to my Bug.
And then I fitted the wheel studs from the hubs off the 951 ali arm into the hubs that came with the steel arms and left off the spacer.
NO INCREASE IN TRACK(over stock at the hub/wheel 'face)
7.5*17et52mm with 225/45ZR17 :silly:
The hubs are the same, I had to swap the studs as I couldn't remove the hub nuts from the ali arms. They're 'bullied' tight rather than secured with a split pin. 'Best undone before arm is removed from the 951. Porschapart take note of this...
Porsche wheel offsets and different track widths can be defined into two catagories, ABS and NON-ABS.
Superman, back me up on this!
To put it simply:-
WE TAKE THE HUGE WHEELS OFF A PORSCHE THAT HAD ABS AND FIT THEM TO THE NON-ABS (Porsche or VW) HUBS/SUSPENSION AND THEY WILL FIT UNDER OUR WINGS (in some* cases)
And remember- BREMBO 4POTS WERE NEVER FITTED (by Porsche) TO ANY STEEL ARMS.
Matt
Old September 2nd 2005, 03:59
This an old post but I thought I would add my findings. I measured drum face to drum face on my 1303 which had type 3 rear drums, it measured 1405 mm when I fitted 86 alloy arms it now measures 1490 mm face to face. The CV bolt flange is about 10 inches (5 inches per side) further out, but owing to the short 86 stub axle lenght I didint get a 10 inch increase in track.
Old July 15th 2006, 10:29
pantswagen pantswagen is offline
hello
does this mean if i have 88 non turbo alloy arms, with thw wider hub and disc
-i can fit the hub from any of either the steel arm or 86 only to them
-and run the early -or a 993 disc
and have the track come in 22mm?
that would save me having to get some new arms???
