Old June 4th 2003, 10:21
Rob's Avatar
Rob Rob is offline
Dual Carb Linkage
Does anybody have pictures or schematics of Dual carb linkages ?
I have a set from a bus, but I can't figure out how the linkage is supposed to work. I want to try and fit it to my Type 1.
Thanks,
Rob.
Old June 8th 2003, 16:35
rip's Avatar
rip rip is offline
did you get the EMPI weber kit? I did.
if you did, the bus type IV linkage drops the hex bar down so it will clear the top of the deck. It wasn't meant for the type I and the hex bar will run into the altenator if you plan on using it with the conversion.
if you got the kit and just need the instructions I'd get the weber tech manuel, it provides a lot of good refereences and jetting information. Plus it will tell you how to setup the linkage. I think they go for about 15 bucks. All in all a good book to have.
good luck,
rip
