Old June 15th 2003, 11:34
chigger chigger is offline
Humm! Why not! Should look pretty good. Lowering it should be easier than a bug as the front uses torsion bars just like the bug rear. I think you are limited to wheel width due to the fender wells not being all that big. The Ghias should have about the same size fender wells if you want to compare. I am not sure if yours came with disk brakes or not, but if it did you can use a bug rotor drilled for Porsch rims in the front and an aftermarket disk brake in the rear. If you use low profile tires a taller wheel is almost necessary as the thinner tire makes the wheels look too small an unbalances the aethics (Just my opinion). I will be looking foward to seeing it.
