Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
Questions about Steve Cs ride
Old September 8th 2002, 09:19
I have ben meaning to pop in here for ages. It looks great, well done.
Steve C
Old September 8th 2002, 12:43
Alex's Avatar
Alex Alex is offline
Hi Steve,
welcome.......you ride is top notch.
2 thumbs up,
Old September 8th 2002, 14:21
Thumbs up
Right on !
Thats one awesome looking bug.
Old September 9th 2002, 01:00
Superman
2 thumbs up
Make that 4
Old November 27th 2002, 16:24
Excellent job!
You have gone an almost unpaved path with a turbo'd wbx. Very daring and from an engineering point of view very interesting!
What is the power output and how is the engine holding up? (how many miles already?, (water) temps?)
Good luck!
Walter
Old November 28th 2002, 08:26
When I had it dynoed the wastegate was not shutting properly and the injectors maxed out and it ony made 128 hp, I was very disappointed with this. I have not yet changed the injectors but i have tidied up other things, fixed the wastegate and made the exhaust less restrictive. I have some Mercedes injectors to be fitted but Im concentrating on other things at the moment so I hope to get things more sorted early next year. I have had a few encounters with WRXs and R33 Skylines and I clearly came out the winner so it must be making more than 128 now.
The motor has been in the car since 1988 but only ran IDAs & 10.5 comp until 2001. The motor has done about 100,000 ks and has only used 2 water pumps and the odd coolant hose in that time, I use VW coolant with distilled water and I dont have any corrosion problems. The oil temp stays around 100 c and water temp around 95 c in very hot weather that we have in Sydney, sometimes over 40 c in summer.
Steve C
Old July 10th 2003, 20:34
Vincent's Avatar
Vincent Vincent is offline
fenders?
Where did you get the fenders? are they still made?
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
Old July 11th 2003, 00:13
Blue74l Blue74l is offline
Steve's guards are called Areo's
You can get them from Vintage Vee Dub Supplies
Unit 1 / 11B Harp Street Campsie NSW Australia 2194 Ph 02-9789-1777 Fax 02-9718-8704
the usual 0011 61 in front
Old October 6th 2004, 01:13
Vincent's Avatar
Steve, How is your 1303 coming along?
Vincent W. Strader
plans
Old October 6th 2004, 01:39
Big Al's Avatar
Big Al Big Al is offline
hey steve and barry!!
Old October 15th 2004, 20:01
Hi Al
Welcome along. Just got back from holidays and Im going to get stuck back into the car now.
