Is your camber correct? If the camber is tipped out at the top they will rub. Are the tires touching the springs. I am running 16x6 55mm offset C-2's on mine and had to run a 195/50/16 up front to keep the tire off the fender. Use a framing square to see if they are 90 deg. to the floor when the car is settled (drop the car and roll it back and forth and put some wieght in it untill it is settled). Then set the camber and toe and see what you have. When you drop it with the adjust-a-struts you will have to re-do the alignment.
