  #33
Old March 12th 2004, 19:56
Originally Posted by nbturbo
I have always told people the Sharpbuilt is a kit that fits straight into a Beetle engine bay.I forgot though that if you opt for the oil cooler in the stock position,you still need to make a small removeable panel to allow the oil cooler duct to clear the body.I have actually made mine a permanent body mod and have welded in the metal bits to hold the rubber to seal against the duct.Will need 2 seals to make it work.If I ever need to fit a standard Type 1 motor back,can just modify the rear removeable engine panel to suit.
it fits straight in if you machine a junk of the case out. only good if you are building the engine from scratch. the thread was started due to sandeep's plan of taking a runnning TIV and fitting it in the car. FAT is the only 911 shroud that allows for this. the DTM is a non-911 shroud that allows for the same. all others that i am aware of require machining.
