Old July 2nd 2004, 03:05
If you have never driven or taken a ride in an 1800 lb. bug with 150 hp stuffed up the back of it you might want to do that before you start planning on a 300 hp powerplant. A 150 hp bug is fairly quick, not alot of stuff on the street will run with it. Stuff 200 hp in one and it is crazy quick. Add the right 5 speed to that ant is is both crazy quick and fast. 150 hp should keep all the hot Honda's and 5.0 Mustangs at bay. 200 hp should keep all the rest in your rearview.
Old July 2nd 2004, 03:14
Mysticle31 Mysticle31 is offline
That's prety much my goal. Best bang for buck 140-200HP whichever gets me there reliably. Is there anything wrong with having a 4 speed? My MK2 VR6 on the track I've only gone 128MPH. Don't imagine I'd need any more, as long as I can cruse and get good gas milage say..60-80. Rarely do I go faster even in the 6 (although I got pulled over going 95 at 1AM, nobody on the road and my inst cluster didn't work. I knew I was going a lil fast but it was soo smooth..) That I don't do..well intentionally.
Old July 2nd 2004, 08:01
Nothing wrong with a 4 speed.
Old July 2nd 2004, 09:11
power to weight is one of the key figures to keep in mind. the other is torque and where it comes on. some engines (rotary, T1) you won't see your power until 4.5k or higher. a TIV will come on about 2.5k. just depends what kind of driving you want to do. by the sounds of it, you lean towards the latter.
i have 176HP at the fly (will know wheels later this year) and expect weight to come in around 1800 give or take 50lbs. that puts me near 10:1. it is plenty.
since i have a standard, handling is sub-par compared to a 1302 or 1303. if i had to do over again, i would probably go 1303, but i like the uniqueness of mine (and benefit) that it is chopped and besides the weight loss i am forced to shift the center of gravity lower by moving the seats closer to the floor.
--low and wide--
Old July 2nd 2004, 14:26
I like that alot. What engine and tranny do you have in your car? I was looking at Massive Type 4 engines. Their nice, but it seems that 148HP is my limit with relibility. I'd love 10:1. What kind of tranny work do you have?
For the same price I can converat a CRX or boost a Miata.. but the superbeetle is all new parts
Old July 2nd 2004, 17:05
Oh I just saw you have a 2316. How much did it cost? Did you have a core to send? How long is it suposed to last? Why not the 2270 C? How do you like the engine? What's your tranny? Do any suspension work?
(one of the questions I have is how hard it is to turn the steering wheel with wide front tires, and how much pedal effort it takes to make the car stop. No power brakes or steering, but it donesn't need it..mabey)
Old July 2nd 2004, 17:59
I built my Yard Sale Type 1 at the MassIVe shop(a great learning experience). I have seen lots of nice stuff come out of there. Jake strives to stay on the cutting edge of things. My last trip up, he was getting ready to test some DLC coatings for heat and ware protection, I saw Nickies for a VW for the first time at his shop, ceramic lifters for a VW I first saw at Jakes. There is a 3L Type 4 torque monster in the works up there called project X, I have seen it in different stages. He is working on some billet type 4 heads with Type 1 exhaust ports (just plain sick). He is very close to having a roller lifter/cam to market for the Type 4. Every time I go up there it is like a trip to Mad Scientist Lab.......well I guess it is. Just when you think you have seen it all,,,,,,the twisted Marine from Cleveland GA. will show you something new.
Old July 2nd 2004, 20:43
vwpride73's Avatar
vwpride73 vwpride73 is offline
I might be a little late on this one but a small displacment 200hp turbo engine will definitely keep almost anything at bay. Remember hp is great but torque gets you moving. Turbo engines and type-4 engine are notorious for making tons o' torque. I'd say one of my dream cars would be the purplish bug with a 230 hp type-4. It was in VWtrends not too long ago ( someone has to remember it). Anyways It ran 12's at the track yet has been clocked on the autobahn at 150mph. Could you ask for more? I think the thing that hinders a VW from being able to accelerate like newer cars (modified WRX and GTI's) at higher speeds would be the gearbox. Blah Blah Blah...
'73 1302/1303
My car - http://www.cardomain.com/memberpage/320620
Old July 2nd 2004, 20:53
That's why I like the type 4's is the torque. Streetable power! just push the accelator and go, and if you really need to go downshift and push the acclerator!
Where can I find more info on turbo engines? Which is a better platform for them type 1 or type 4?
With Jakes kit I'd think that the kit would actually be more expensive then the built engine as the built engine has the induction and ignition. The kit is a longblock. From what I read the carbs are mucho money! What is the price drifference? I wonder if I could rig up a reliable turbo or eaton supercharger from a car to some 1776 type 1 or some type 4? Reliable?
Old July 2nd 2004, 21:04
vwpride73's Avatar
I have only seen one turbo T-4 and no numbers where mentioned. You can make a 1776 make 150-160hp reliably or make a 2332 make 250-275hp reliably with a efficient turbo set-up (key word is efficient) . I imagin the torque numbers would be the same yet sooner in the RPM band. A T-4 with a turbo would probably be the ultimate street/strip/road course engine. Imagin it... smoke anything on the street(when traction permits), destroy cars on the strip and be able to beat most anything on the track(if the car can turn). In all reality its all about the combo and what you want/need.
'73 1302/1303
Old July 2nd 2004, 21:16
How do you cool such an big engine? Becouse they always say that boot is like having a larger engine. How do you cool it? IE the type 4's at say 150HP all have DTM cooling or Porsche cooling?
No computers, just fuel regulator set a few points ahead of the turbo! just a little tiny tiny turbo..
Old July 2nd 2004, 21:21
boygenius's Avatar
DTM with nickies should be able to handle the heat.
Turbo EFI with stand alone engine manegment is the only way to go.
Old July 2nd 2004, 22:45
vwpride73's Avatar
Yeah I mean it does say dream car! Get crazy. But really if I had money to burn I would opt for a split window bug, custom tubular frame, big turbo autocraft engine, mendeola five speed, totally custom suspension (set-up for road course), big 911 brakes all around, 17x7.5 front and 17x9 rear and interior stock except for a rollcage, buckets, couple gauges. pretty much the only thing thats original are interior items and the body. All of you elitest can kiss my arse.
'73 1302/1303
