Old July 6th 2004, 15:08
rip's Avatar
rip rip is offline
Saco hydro clutch
I was wondering, I remeber a while back that a few guys here installed the Saco Hydro clutch, I figured on using a solid line, but all in all hows it holding up?
Good enough for daily driving?
Also if I cut a hole in the side of the tunnel, how big can the hole be? And will the tunnel be weaker, do you need to brace it? Or weld in back up?
thanks for the help
Rip
Old July 15th 2004, 16:53
Hi Rip,
I am still underway with the engine,but Yes, I will use a solid (actually a line we use for brake line) line when all is done.
The needed hole is specified by the instructions. I wouldn't worry too much about it. I dont at least
Greetings,
Walter
