Old July 22nd 2004, 12:42
elroocky's Avatar
elroocky elroocky is offline
Question strange type 4 big bore kit..?
hello guy's we have found an old NOS kit of cylinders and pistons in diameter 100mm, but without precise mark, the kit is made for 66mm crankshaft and boring is 99,98mm. the boring is flat but renforced out of matter to make release in the pistons for the valves (just for 2 valves)
the cylinder is lined cast iron with an aluminum envelope. the pistons are just located by "UP91" and a code "FF" on the side.
the pistons look like wiseco, short skirt and are released around the sides of the axes, the axes its in 24mm
does somebody knows something more than us about this kit..? factory.? a name.? built by who..?
thanks for help
david
ride a type4.. it will change your life.....
Old July 23rd 2004, 03:44
Hi Elroocky, a bit off the topic but is Remmelle still around? Last I heard he is relocating! By the way, what is the size and et of your rear wheels and the fender size?
T4 2666 1303s
Old July 23rd 2004, 04:19
elroocky's Avatar
out of topic.. but..
hello silver bull
check ou on my ride, all information are on it, rim's are 10,5x18 and 9,5x18 with + 4cm and + 5cm on rear..
remmele is back,and opened in germany again he rang me a few week's ago, he is near "bürt" in a small town, it's very near the french border. (around 12 miles)
I dont have the adresse and phone with me, I will drop you that tonight, when I'll be back at home..
david
Old July 23rd 2004, 17:50
yetibone's Avatar
yetibone yetibone is offline
Elroocky, regarding your original post, I belive that 20-odd years ago that SCAT or Empi made some 100mm alusil or nikisil cylinders but didn't continue production due to such small demand for those parts.
The way you described yours, it sounds like they're Biral cylinders. I'm not sure if SCAT or Empi made any of those, but they would be likely candidates for their manufacture.
I hope this helps.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 24th 2004, 04:49
elroocky's Avatar
Question
it's for shure a Biral kit, main cylinder is cast iron with envelope aluminum, it rather light and lighter than an 94mm original cyl/piston, and it is clear that it is not recent, except that nothing does not make it possible to identify it. I will make photographs and drop them on the site.
Even on the seals, nothing appears, nothing on the piston axis.. or what ever..
Old July 24th 2004, 07:05
elroocky's Avatar
pics
here are 2 pics, that maybe will help..
the iron cast cylinder is very thick, would be very easy to modified and get in a 103mm piston
does anybody have any informations..?
david
Old July 27th 2004, 04:16
Hi david,
Very cool kit! Nice find indeed.
Sorry, never came across them.
Greetings,
Walter
Old July 27th 2004, 10:16
elroocky's Avatar
very cool..?
well very cool is a big word, that make's a 2074cc on a 66mm crank or 2230cc on a 71, but, I dont know if there is a change to get any spares in the future... where to get new seal, gaskets or what ever..?
david
Old July 29th 2004, 08:32
david
The cylinders look long enough to see if a longer stroke would be possible within those cylinders
Also these birals are ideal for a turbo-project. Think further. Seals, gaskets you would have to let them make
Good luck with them! (unless you want to sell them on, then call me)
Greetings,
Walter
Old July 29th 2004, 10:46
elroocky's Avatar
not yet
well wally? I'm going to have a try first.. before salling them for seals, no prob, I have an adress where they can provide them, all style all dimensions, a friend give me it yesturday, I feel more confident with it now..
more informations..? all are welcomed
wally, what would you do with that kit? ( with turbocharged type 4) and infos..? a precise engine chart.?
Old July 29th 2004, 12:44
starmember's Avatar
It looks like a Nippon but i`m not sure.
Old July 30th 2004, 01:52
Not sure what the set exactly is, but it would make for a fine cool riding engine for my daily squareback
No problem, its just a possibility.
Greetings,
Walter
Old August 8th 2004, 21:06
Ephry73 Ephry73 is offline
I would use a 76mm stoke crank with that, or just the 66mm. Looks like a great find, and if you ever need to get RID of them, please let me know.
Great, great find.
E
Old August 9th 2004, 04:18
elroocky's Avatar
hum humm
it look's like everebody is starting to love this "middle size boring kit". and forget it no way...
I'll have a try on a 66x100, that could be an excellent 2074cc for my next toy as a 914 to replace the old 1971cc...
I'm looking forward for a chart , I need to see..
Old August 9th 2004, 04:31
mikko k mikko k is offline
Hello everybody. I had about 10 years ago from Scat just like the same set. The piston were lower for longer stroke, but cylinders seem to be alike. Something happened to the set in my friends car, but I don't remember what! I still might have some cylinders in my store.
