whooops that was reallll smart.. anyways its a 1971 1302 super.
from the local shop.. this is what i have come across.. i dont know everything i should be buying.. so here is what i have so far. Front Disk Brakes -$270 http://venus.myhostfiles.com/~peekpe...ce5501a5274794 Rear Disk Brakes -$330 http://venus.myhostfiles.com/~peekpe...ce5501a5274794 Lowering struts -$150 http://venus.myhostfiles.com/~peekpe...ce5501a5274794 lowered strut insert shock -$80 http://venus.myhostfiles.com/~peekpe...ce5501a5274794 i dont know if i will need lowering springs if i have lowerd struts or what. i am guessing with the shocks. also i havent seen anything for lowering the back end.. how is that done? Last edited by kakarottt; September 26th 2004 at 21:43. |
Hey Kaka, here is what I got/need for suspension/brakes.
Front '86 (83-86 are basically the same)944 brakes, everything from spindles out, $69 ebay complete rear suspension '87('87-89 are the same, 85.5-86 won't widen the track as much, and 83-85 control arms are identical to the vw units with a little more internal renforcement) 944 N/A, thats everything including brakes and axles, $140 ebay Topline Maxx three bolt struts w/ 7/8" swaybar, $600 from www.toplineparts.com Need: machine work to 944 hubs and 1302 spindles approx $300 by Laner at VDubCustoms. New pads/rotors/ and caliper rebuild kits, $388 www.pelicanparts.com if I really want to go crazy for an extra 600-700 I can go with the 4 pot Brembo 944 Turbo calipers. What I wish I had done differently, is I wish I had bought the 2 bolt struts from Topline and then the 944 spindles are basically a bolt on deal, but the the early Supa's have beefier cast control arms as opposed to the later 2 bolt 1303 struts with their flimsy stamped control arms. I'll be happy with my three bolt setup none the less. There are several tech articles about these conversions and a whole lot of informative threads if you do a search. You will have to run Porsche wheels after this. |
"the 2 bolt struts from Topline and then the 944 spindles are basically a bolt on deal"
sounds like a plan to me. i know a 944 i could pull these off of. but the wheels/tires would put me over the top though.. |
You should checkout Topline, www.toplineparts.com
front lowering kit for $300 front disk kit for $300 ball joints $45+/- for the pair idler arm bushing $50 Bushings (control arms/sway bar) $40 steering dampener $30 bump steer kit-$15 upper stress bar- $100 (i think) add another $100 for sports plus springs. These are tappered and allow a little more room for higher offset wheels (no more than 38mm i think) If you need more room, you'll need coilovers, like the maxx struts.
=EuroLook71= 71' Super Beetle 1.6L DP - Kadrons, stock heads P&P by me
