Old December 26th 2004, 21:08
will need to know width and offset to say for sure. they are most likely 9" with a 55mm (or maybe 52mm) offset. things can get tight under stocks, but pretty sure it can be done with some creative trimming. certainly can fit under wider ones (i run 8.5ET48 under 3" with 944 wide trailing arms). but with stock arms you would run into having to spacer them out then.
what are running for an engine? anything other than stock, i would not suggest running those rims. you will lose all sorts of power trying to spin the larger and heavier rims.
