Old January 8th 2005, 19:48
beet beet is offline
944 front brembo caliper problem
i´ve in my 77´ 1303 cabrio all porsche 944 brakes with a single piston calipers around 4 wheels. i´ve kerscher struts at front with 944T spindles.
The problem is when I go to put the black brembos at the front. in the rear, i only put some spacers to center the caliper in the disc, but in the front.... The Ate caliper mount holes are smaller than brembo´s holes!!!!! what can i do? i know that my spindles are from a 944T but i don´t know year... the disc is mount rear the hubs... i need help please.
Old January 13th 2005, 00:01
ajracer ajracer is offline
Mounting Dimensions
No expert here, but my understanding is that most of the older Porsches used
3.0" spacing between the mounting holes; But the later Porsches used 3.5"
mounting holes. Your Brembo's will be 3.5" spacing between the mounting
holes. You can usually fabricate an adapter or you may have to replace your
struts with a Porsche 911 type that wil give you the correct spacing. Your
could also sell the Brembo's and replace with something else designed for our
loved Beetle. Good Luck
Allan
Note: 1977-1989 Porsches 911 used 3.5" spacing
All 914 Porsches used 3.0" spacing
1972 Super
Old January 20th 2005, 23:00
Superman
Originally Posted by beet
brakes with a single piston calipers ... at front with 944T spindles
That's the problem. These do not interchange, the single piston mount is 76mm and the four piston mount is 94mm. You will need 944 (not Turbo) spindles.
