Old January 14th 2005, 09:30
GS guy GS guy is offline
Thanks for the reply Sandeep. Not quite sure how one would go about enlarging the shock bolt. From the looks of my T-arm, it looks like the shock mount is basically a round pin with threads on one end - a separate piece that is probably press-fit into the arm forging, then pinned in place with a small anchor pin. You'd have to first remove this shock mounting pin (whatever that would entail), then bore the hole oversize in the T-arm and press fit a larger mount/pin. Not a minor task!
Think I'll just follow reports for a while and see how these hold up in stock form. Thanks, Jeff
