Old February 3rd 2005, 05:20
Bruce2 Bruce2 is offline
As you know that trans is for a mid engine application. Turning it around would require flipping the Ring gear to the other side. Does it look possible?
The VW shift rod is at the front of the trans, using a side shift trans is a waste of time given that you can simply use a 911 gearbox that has the shift linkage at the front of the trans, right near where it needs to be for the VW.
Any mod is possible, buy why spend tens of hours and hundreds of $ when a better trans already exists for the swap?
