			#46
			So yesterdayevening I had some time, so I have worked on my cage.
			The first piece of the cross in the cage is ready and is till thursday tacked in. ![]() Under http://www.keversite.nl/fotoalbum/fo...2005211031.jpg Above http://www.keversite.nl/fotoalbum/fo...2005211057.jpg The other half of the cross is made almost on the right size. Here a little pre-look at it. ![]() Greetings Wiebrand
	B-Extreme B-Tuning..... Racebug is comming to get ya!!!  |
			#47
			So finally I had some time to get on with the cage again.
			At first an brither pic of the cross in the cage (not totally ready yet). http://www.keversite.nl/fotoalbum/fo...2005230215.jpg And anbetter pic of the welding on the back wheelarces. http://www.keversite.nl/fotoalbum/fo...2005230528.jpg At first I had maked two other holes in the dashboardplate so that the tubes from the struts can go to the cage. Pic from the inside (driversside). ![]() Pic from trunk (driverside) http://www.keversite.nl/fotoalbum/fo...2005230812.jpg Also we had bendend 2 tubes that will go in front of the doors from the a- to the b-pillar. ![]() After that we welded brackets on the tube at the a-pillar. So that the tube from the strut can be mounted to the cage. Driversside http://www.keversite.nl/fotoalbum/fo...2005231044.jpg Passengerside http://www.keversite.nl/fotoalbum/fo...2005231132.jpg
			#48
			There's also an bracket welded tot the long tube (from the strut tot the cage) so that the short tube can be mounted from the strut to the cage.
			![]() An detailpic of the bracket welded on the long tube. http://www.keversite.nl/fotoalbum/fo...2005231344.jpg And FINALLY the front of the cage is READY. It was about time!!! Seen from the trunk. ![]() From the interior. ![]() See ya next time Wiebrand
			#49
			It looks solid there man...nice job! :agree:
	There is no cure for our disease   '69 standard ( under the knife) '72 1302 GL ( under the knife and on hold) VolkSport Kfer Gruppe www.VolkSport.net  |
			#50
			good job !!!!!!!!!!!!!!!!!!!!
			:agree: you don't want to come in France for one or two weeks ???      I have a small job for you !!!......
	2FAST4U  |
			#51
			wow
			WAKE UP, WAKE UP:
			It's time for another update. Last week I've begun starting to bend the last tubes for the cage. http://www.keversite.nl/fotoalbum/fo...2005001341.jpg And that gives this final result. ![]() It need to be shortend on the right size and then also this one can be welded in. Also is the cross welded in. http://www.keversite.nl/fotoalbum/fo...2005001514.jpg And that gives this nice picture (if I may say). ![]() Here some detailpics of the welding http://www.keversite.nl/fotoalbum/fo...2005001624.jpg http://www.keversite.nl/fotoalbum/fo...2005001729.jpg Grt. Wiebrand
			#53
			Yes, yes 2 updates at one tim
			  .The second-last tubes are welded in last sunday. It are the two tubes that goes along the doors. Picture from above. It's good to see that the tubes clears the door all the way. ![]() Picture of the to welded tubes. http://www.keversite.nl/fotoalbum/fo...2005231032.jpg ![]() http://www.keversite.nl/fotoalbum/fo...2005231158.jpg
			#54
			Detail pic of one of the weldings in the cage.
			http://www.keversite.nl/fotoalbum/fo...2005231301.jpg And at least some total pics of the cage so far it is now. It must said that 3 tubes are not yet in on this picture and that 1 tubes still needs to be welded in. ![]() http://www.keversite.nl/fotoalbum/fo...2005232307.jpg Mondayevening also 2 tubes mate on the right size. http://www.keversite.nl/fotoalbum/fo...2005232427.jpg 1 is ready and fits really nice. ![]() Grt Wiebrand
			#55
			:agree:  :agree:
	'79 Karmann, Nrburgring or bust...  |
			#56
			How much experience do yo uhave with Fastbacks? I got here waiting for you....
			#57
			a new update wiebrand ????
	2FAST4U  |
			#58
			Mwhaa Ben.
			There's only an verry little update of the cage. The "fixingtubes" are widered (uitgedraaid in het nederlands) for the right diameter and are drilled so that the several pieces of the cage can be bolted together at the end. The next update will be over a couple of weeks I'm afraid because I'm now verry busy with the chassis (new fuellines 2*12mm and new brakelines). When I've fixed that I will paint the chassis and the cage at the same time. Wiebrand
			#59
			ok wiebrand !  :agree:
			good job !!
	2FAST4U  |
			#60
			If I'm not mistaken the correct therm for "widered" is machined off (als ik me me goed kan herinneren van de Engelse les vroeger tenminste)
