Old April 4th 2005, 17:20
kakarottt kakarottt is offline
225's up front?
i just bought a set of 4 phone dials for my super. i plan on getting disc brakes all the way arround or maybe just up front and get a set of blank drums for the rear. I put the wheels up to the front brakes and they hit the spring on the inside. will 225's fit without any spacers if i buy the topline struts?
Aircooled :bug
Watercooled : computer
Old April 9th 2005, 01:25
rip's Avatar
rip rip is offline
I don't know about the front. Mostly 205 and the occasional 215. They should work in the rear though.
Also how wide are phone dials? There are guys here with more experience with supers than I. But I'm pretty sure the thinner springs are a must for anything larger than a 7" rim. And I don't know if I'd run a 225 on anything to much smaller.
Good luck
Rip
Old April 9th 2005, 09:26
agree. 205 is the size of choice for most. your phone dials shouldn't be any wider than 7" which a 205 will be fine on. i am not certain, but doubt you can get a 225 on there. the super guys will jump on here and confirm though.
Old April 9th 2005, 10:36
well i already got 4 matching tires and they are all 225, i was going to at least get as far as i could with these until i broke down and bought a smaller front tire.
7 inch phone dials, 4.5" back spacing from the rim. 5.0" from the tire.
Aircooled :bug
Old April 10th 2005, 01:32
jrinlv jrinlv is offline
looks like you got an extra pair for the back. JR
Old May 1st 2005, 21:47
THEY FIT! with room to spare =)
Now i just need to get my rear drums drilled and studs pressed so i can drive it. but no one seems to want to do it!
Aircooled :bug
Old May 2nd 2005, 15:42
dean_harryman's Avatar
dean_harryman dean_harryman is offline
you might want to check if you will rub when to turn......I have a 64(not a super) but You might have the same problem as me...I have 205's on my bug and if I try to turn sharp..like in the driveway...my tire rubs on my sway bar....just a thought....
Dean Harryman
Grants Pass, Oregon
1964 VW Bug "Reismeuchelmrder"
Dean_Harryman@hotmail.com
http://www.cardomain.com/memberpage/632917
Old May 2nd 2005, 16:02
I guess i'm just lucky.. i went down and cranked the wheel all the way both directions and checked.. it doesn't touch anything either way i turn it.. unless it rubs against the fender when i put those on.
Aircooled :bug
