View Poll Results: Which will give you the most long-term bang for your buck!
air-cooled stock 4 16.00%
air-cooled High Output 8 32.00%
water-cooled conversion 13 52.00%
Voters: 25. You may not vote on this poll
Old July 20th 2005, 02:26
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
Ecotec
The best bang for the buck in my book are the newer ecotec motors. You can buy the motors with 10,000-20,000 miles for $250-$400, stock hp is 140, w/computer 170, N/A with mods and computer 225, Turbo with stock internals up to 380, Turbo with internals... anything up to 1390 (thirteen hundred and ninety) hp! My friend has 18,000 miles on a turbo stock internaled 2.2 cavalier with a T3/T4 with 350 hp @ i think 15 lbs of boost. Power and reliability. $2500 for motor, computer, turbo, and adapter.
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old July 20th 2005, 10:20
oicdn's Avatar
oicdn oicdn is offline
^^ Hahaha, the problem with a a cavalier is though...is it's HEAVY AS HELL....I think around like 3400lbs heavy. Holy hell, a G35 and other LUXURY cars weigh that much and have a huge V8 or V6 in there with tons of other leather heavy interior crap.....
Been there, done that.
Also, that rear suspension SUCKS. He'll have ALOT of catching up to do to match what the beetle has to offer.
I would also like to see where an ECU gives 30HP on a stock motor. Not to burst your bubble, but those HP numbers are a bit inflated. It's a great motor, sure, but meh, There's better performance out there for less money. Yeah, the motor is cheap, but the fact you have to fabricate to get it in, just so you have 140HP of electrical GM headaches, is not worth it to me. You have to spend another $1500 on fabrications to get 140HP...then on top of that, the mods to get the motor in the high HP area....not worth it. In the end you just spent a ton of money when you coulda got either a Type 4, a Porsche conversion, or a Subaru conversion.....started out with a higher BASE HP and a bigger aftermarket. And well, you'de end up spending all that money on fab, why not get something that works out better in the long-run...
....I dunno, I don't think I'de want a GM product in my dub...
Old July 21st 2005, 04:57
Strange poll; too many variables to make viable statements.
F.i.: I don't want a watercooled engine in my aircooeld VW! But a stock 200 hp Subaru will always have a longer life than any tuned aircooled engine that started out as a 50 hp (type 1) or a 100hp (type 4) engine...Duh!
Most bang for the buck is not my or most peoples goal. Than everybody would have a watercooled conversion in their car...
Oh, I drive tuned beetles for 20 years and 18 of that with type 4's in my bug (and type 3's). I have never broke any engine, or took it apart because it needed an overhaul or s/th like that. They always came apart because I wanted to improve them or make them faster or both so I really can't say anything on your poll
Best regards,
Walter
Old August 1st 2005, 21:49
Bump, keep em coming.
Old August 2nd 2005, 17:41
cnavarro's Avatar
cnavarro cnavarro is offline
I'm with Wally, most guys aren't looking for bang for the buck. You can easily afford weight wise a heavier engine that makes more HP and handle the tradeoff that 15hp is needed for every extra 100lbs.
One of Jake's 2270's is the perfect balance of performance and longevity. Anything more and you need to start shelling out big bucks for longevity and reliability (i.e. Nickies).
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old August 3rd 2005, 16:40
Massive Type IV's Avatar
Last night the 3.0 turned 9000 miles since it's birth in March 05.....
I cahnged the oil when it came off the dyno, but not since it was installed in the car.... (trying to promote wear)
It hasn't used but a tad over 1 quart of oil over the 9K span its been in the car... I average 75 MPH on the highway at 25-27 MPG...... Engine produces 196HP to the rear wheels and 235@ the flywheel at only 5500 RPM....
The longevity of a correctly configured and assembled engine isn't a damn bit less than a stocker -- Do something wrong, mess up the combo or run it lean and things drastically change.
Jake Raby
Old August 5th 2005, 13:10
oicdn's Avatar
damn...yeah, I wasn't sure if I was reading it right on the other forums. But aren't you usinf Royal Purple motor oil? If you're promoting wear, why didn't you use another motor oil like Castrol? Or, if you want the best oil, why not use Motul or Redline?
Bah...I'm going on a tangent here....
Sick to see it running so well. But I'm curious on something though. That motor in your car is probably a $25K+ engine if we were to buy it...so I think that statement can be a little misleading right?
Misleading in that, if we were to do the same 9000 miles and no oil change since the dyno, would one of your "off the shelf" motors still run as efficient? I'm assuming yes, but...I duno, something that i just thought I'de ask....
