You've definately pegged the WOW meter for looks, I'm afraid you might be saying, wow, this sucks to drive. They weigh a lot more than needed, so your sprung weight is way up, and they are soooooo much more than is needed to stop a light car that I don't know if they will even warm up! If your doing it for looks, you're on the right path and they look AWESOME! But if you are doing it to drive, I think you might be on the wrong path.
Just to let you know that there is no way in hell I would ever drive a 550 hp 1800 lb. rear wheel drive car in the rain. Never mind the braking factor.
I don't see a problem of sprung weight because if you look at the ultima gtr (the fastest production car on the planet, 10.5 @ the 1320, 0-100-0 in 10.3 sec, and 1.176 in lateral G's) has simalar style brakes on a 2000 pound car (it's also street legal), and obviously by the #'s it doesn't have any problems getting around. On top of that, brembo's 8 piston setup is for the front of 993 and 996 cup style cars that weigh closer to 2500 lbs..And my car will probably end up being 2000 lbs., with a turbo charged inline 4, 6 speed g-50, 993 rear end, and these brakes. I wouldn't have gotten something this big if i thought they would be counter productive. The caliper is suprisingly light weight. Endless brake company makes a 12 piston, 17" rotor brake setup for the front of SUV's that want to fill up there whole wheels with brakes when using 22's and up. That i might add would be counter productive. Also, the rotors will be crossdrilled. Check out how wide the rotor is, 1.3" thick! Contact patch will be 255/18's up front and 315/18's out back. Anything to get 1.0 lateral g's. Moto of the German Look Style of tuning: FORM FOLLOWS FUNCTION. Not the other way around.
1974 type 1 Turbo 6 piston brakes at all corners ![]() Project is taking all my money and it's all Germanlook.com's fault! 98' Audi A4 93' T-Bird (oh yeah!) 90' 911 C2 74' beetle |
The ultima is also not a VW, and any idea how much the ultima costs? I'm all for getting nuts, but brakes are just one of the variables in an almost unlimited number of them for the project you have in mind. I'm not trying to give you a hard time here, I'm just trying to inject a bit of reality. If you are going to give everything you do on this project the same type of overephasis, you will end up with a bug that costs $100k. Look at Bader Racing's Ghia, do you think they make a lot of sales or a lot of money with those? It's awesome, but pricey.
Me likes, me likes!
I'm poor so i'll probally just end up using my 944 N/A calipers. Don't look cool like the Brembo counter parts but will do the job.
I have based a lot of my life in making sure i can make the project go smoothly (aka emergency money in savings). I expected criticism, but not from other people who are doing similar things to there Dubs. I will have proportioning valves on both the front and rear circuits, as well as the expirtise of Lanner. I have no doubt that with Lanners advise, the setup will be nothing short of well balanced and very streetable. Thanks a lot for all the input, i'll include pictures of other similar overkill additions to my project in due time. Russ
We're not saying it's crap...it's FAR FROM it...it's just a little counter productive.
The Porsche's with the 8 pistons are also slowing from insanely fast speeds. Also, those Porsche's have perfect braking surfaces at all times, with a track that's also heated with racing tires. Granted you will have the motor to make up for the unsprung weight, I'm just saying the car will not be "streetable". As the brakes will be a little too strong. Another thing I was looking at was pan/frame fatigue. Unless you go semi-or tube chassis, you might want to look into getting your shell AND pan reinforced as the lateral braking forces will deifnitly put a strain on the thin gauge metal. The Beetles pan/shell wasn't designed for that brutal of a stress. I mean, the forces a motor puts out in terms of twist from the HP/TQ of a motor is FAR LESS than that of 6 pots under full braking force, and you need all sorts of braces/reinforcement for 250HP.... But it's DEFINITLY a sick thing you got going on....just things to think about. |
Point #1-The Cayenne has a brake booster. Point #2-I'm using proportioning valves on both front and rear circuits to make it more street friendly. Point #3-The car WILL be used every day as a daily driver. Point #4-You guys are awesome for all the input Point #5-The chassis will be fully reinforced from the front to the motor mounts with a 14 point cage, and the heater channel replaced with square cro-moly tubing. Point #6-The car will be used for circuit races as a new track is being built by Larry H. Miller in Toele, UT. (about 1/2 hour away), so the car is obviously going to be a little over kill.
Those are "F___ing" big. My 2 pot ghia brakes on all 4 stop like hell (although not repeatedly, ala auto-X). Those are more than likely over-kill,,,,,, but they sure do look cooooooooooooool. Be carefull.
One thing is for sure. You will never suffer from "Brake Envy".
