Old May 27th 2006, 00:35
chug_A_bug's Avatar
Thumbs down IGNITION no power to coil
hey guys this it dumb but I HATE WIRES so bugs been sitting for the winter adn now it wont fire, I had to put a new 30 carb and coil wire and
PERTRONIX IGNITION KITS for a 69 bug new battey, ok so here is the problem I got power from battery to the regulater to the IGNITION
but not to the COIL what am I missing?? thanks guys.
chug_A_bug's Avatar
all fures are good, I have one of those PERTRONIX IGNITIONS you just hook up + and - to the coil right? and anyother Ideas to get it started?? would help alot. thanks
Old May 27th 2006, 02:17
Did you check for 12 volts on the + post of the coil? If you don't have 12 volts at the coil try twisting the fuses or cleaning the fues holders in the fues block, some times they get oxidized and loose their connection. If this doesn't work "T" off your left rear running light to the + side of the coil and turn the lights on to get it going. If it runs then, you might need a new ign. switch.
Old May 27th 2006, 03:51
speedy's Avatar
speedy speedy is offline
make sure you connect up the pertronix unit the correct way round or you will damage it and have to by another , the coil sounds like a blown fuse
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 27th 2006, 08:09
chug_A_bug's Avatar
Cool
hey thanks guys for your help I'm off now to work on it all day today so I'll be on you lett you guys what happen later today. thanks again
Old May 27th 2006, 17:52
73 sportsbug's Avatar
73 sportsbug 73 sportsbug is offline
the coil isn't fused, power comes directly from the ignition switch
rusticus maximus
