Old August 9th 2006, 02:37
LLVWGL LLVWGL is offline
Porsche Tire/Wheel clearance
Hi Everyone!
I am just buttoning up my porsche 944na brakes, and 17x7/9 (et55) wheel installation. I am running 205/40/17 tires in the front and 255/40/17 tires in the back.
My question is about clearance between the tires and suspension components. Ex. spring plates/bump stops in the back and the strut spring in the front.
The way it is now, I have about 1-3mm of clearance between the tire and any given component. I have been told that if i am driving aggresively the tire will flex and rub said components.
Should I be concerned, should I use spacers? How much do you think the sidewall of a 40 series tire will flex?
Thanks.
Old August 9th 2006, 05:37
I think 5 mm clearence would be minimum with a really low profile tire. With a 'normal' tire like 195/65 or a 205/55, I would say 10mm should be safe.
I know what it is like being stranded with your family in the car with a flat, torn tire because of too little clearance..
Regards,
Walter
Old August 9th 2006, 21:24
Well, I suppose that I'll look into some spacers then.
