Old October 14th 2006, 13:30
Moog's Avatar
Moog Moog is offline
Hi Rich - Thanks for answering. I'm thinking and hoping it is just the cap, but am slightly nervous that there might be something else wrong.
Temps - The standard thermostat on a WBX starts to open at 87°c and is fully open at 105°c. I actually have a VR6 stat which starts at 80°c and is fully open at 100°c, so with normal water operating temps at 90-95°c then i figured this is fine. My choice of rad location probably does make it run a bit hotter than if i used a front mounted rad, but i don't think that it is getting too hot for the engine or system to take. I have the ECU controlling the fan - cuts in at 105°c and cuts out at 95°c. (All temps are measured at coolant outlet from the engine, so at the hottest part of the system before the coolant has gone though the rad). If i recall, the Mk2 GTI ran quite hot like this as well, so the tank should take it if the cap is working properly. Maybe i'll trim the fan operating temps down a bit as well and see how it goes.
I have found out the Golf Cap is rated at 1.2-1.5bar, while the T25 cap is 0.9-1.15bar, so will try a T25 cap with spout and an additional non-pressurised overflow/filler tank as per T25 and see if this works.
Heater matrix is a std T25 auxilliary heater under the rear seat - takes an outlet from the left head and returns into the top of the water pump (T'd into the hose from the header tank to water pump) so similar to T25 setup.
I did think it may be to do with the overall coolant volume being too small, but the standard Golf Mk2 GTi is listed as 6.5 litres coolant volume (smaller than i thought), and i have about the same.
New bottles & caps coming Monday, so i have to just sit and wait until then - very frustrating... still, at least i might get some more plastering done in the kitchen...
Ta
Moog
(o\ /o) '73 GT Beetle with 2.1 WBX (owned since 1990)
(o\ /o) '74 Jeans Beetle (owned since 1986)
(o\ /o) '67 Zenith Blue Beetle (needs lots of work..)
'02 Passat Sport Diseasel Estate ("Das Boot")
'05 Seat Leon FR, chipped (Mrs Moog's toy really...)
Old December 24th 2006, 18:05
Tony Z Tony Z is offline
My first thought is also the cap
But I do have another idea.... what about vibration?? Is you header tank mounted on rubber mounts or straight onto the firewall?? You could be rattling the thing apart.
Try this. Make a plate to mount your tank onto. This plate... mount it to the firewall using 2 flexible rubber mounts (used for mounting small motors and pumps). Mount the plate onto thie mounts and mount the tank onto the plate. Then get some (2) rubber straps and tie them around the plate and the tank. This will allow the tank to be fairly rigid to the plate, while not recieving the vibrations from the car.
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
Old December 26th 2006, 09:34
The only time that I had a problem with my old car with a wasserboxer fitted was the cap.
A radiator place should be able to check the cracking pressure on the cap you have now.
Will a T25 cap fit your Golf header tank OK? I actually prefer to have a recovery system like the T25, its good for getting rid of air locks.
Old December 28th 2006, 10:57
Moog's Avatar
Thank s for the suggestion. The header tank is standard golf that is supposed to be fixed to the body - it isn't meant to be flexi mounted. Plus if it was this then it would split at the mount of where connections are. Where these split is clearly due to overpressure, so i don't think this is it.
I have now replaced the cap with the T25 one with spout and an extra catch tank, and all now seems resolved. Must have been a faulty cap, even though it was new 500miles ago.
Ta for the advice all.
