Old March 3rd 2007, 19:16
Angelo Amato's Avatar
- - - Update - - - Update - - Update - -
right yesterday ordered a 944 m/c and it arrived this morning . Went to collect it (genuine ATE £97 UK pounds)
..thought it would be tricky to fit with front/rear outlets being vice versa, but the front pipes reached the rear outlets no probs, and the rear, well when i fitted a 'T' for the switch and made a stubby pipe to go to m/c all fitted well !
the other possible stumbling block was goung to be the reservoir pipes into the m/c. the 944, as bug ones as large dia. fittings that go in. my Audi m/c as for the type 3 one has smaller ones - the type 3 has one of these fittings real flat so the tie rod can pass over it, but these ones were too small for the 944. i had a new set of proper bug ones, fitted them and re-routed one of the res pipes over the tie rod - thought i'd be tight on space with gas tank but plenty of room! so another problem sorted !
the piston rod on the pedal which i had previously extended for the audi m/c (by 15mm) was perfect for the 944.
pressure bled the brakes again..
lo and BEHOLD- I GOT PEDAL !!!!!!!!
All I can say is many thanks, especially to Lanner for the 'logic' and thanks for the power of the internet and sharing of information
pics below. just to prove a 944 m/c CAN be fitted to a type 3.
Cheers guys, Angelo
LONG LIVE THE GERMAN LOOK - THE HOME OF INNOVATION !
Type 3 Fastback
Old March 3rd 2007, 19:17
pics
Type 3 Fastback
Old March 3rd 2007, 22:12
That look's killer! Congrat's on the plumbing, and the T3.
Old March 4th 2007, 14:36
flat flat is offline
Looks good. And DAMN! That's a clean car. I'm sure I and everyone here appreciate your efforts. It's one less thing for the next guy to figure out.
Is there such a beast as a 944 right hand master cylinder? Or are they all the same worldwide? (The one you have is the same as the ones I use on this side of the pond, a LH one).
www.vdubengineering.com
Old March 4th 2007, 15:23
1303R's Avatar
1303R 1303R is offline
hell yeh thats clean. only a bit jealous, lol. anytime i go near the underside of my car i gets covered in crap. i'm pretty sure my m/c that came off a n/a 944 has the front outlet on the other side. oh does the brake light come on early enough with that setup? i fitted a push type switch on the pedel itself cus heard light wouldn't come on soon enough with big brakes?
Old March 4th 2007, 17:43
clean ?
been doing this project for several YEARS !
will reveal more pics nearer to it's launch.
hoping to get it to the shows. look out for it.
was aiming for Volksworld but not going to happen.
..couple more spy shots !
Type 3 Fastback
Old March 6th 2007, 05:29
Racelook's Avatar
Racelook Racelook is offline
Nice project :agree:
B-Extreme B-Tuning.....
