Old June 27th 2007, 11:47
Chris Percival's Avatar
I have just done this. Write up to follow soon on www.fastbug.net. 944 aluminium hub machined and then fitted with steel inserts to take beetle bearings and oil seal. Drum axles used and all I need is the correct shape steel plate and a spacer to hold the brake caliper. I created detailed CAD drawings which I will also make available.
