Old September 26th 2007, 21:01
Bug@5speed(US)'s Avatar
Camber plate info, FYI
Came across another company that actually carries camber plates.
Thru carreracustom.
POC is Stephen Ellis @ Phone: 704.841.2614
E-mail: CarreraCustom@carolina.rr.com
One of our members here had posted about them.. I have been conversing with Steve on the subject, as I need them to band-aid my +camber due to my porsche spindles.
There are two different plates for early 3 bolt and later 2 bolt suspensions.
I am looking at getting the 3 bolt which is Part#9941875V
Payment can be made with credit card, money order or personal check.
Total Cost $369.35
Just passing the info.. I need to ask him how much camber is allowable.. but feel free to write to steve.. I have a pic of the setup that I will host hopefully tomorrow.. Its on my work computer..
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old September 27th 2007, 10:08
Here is the best I can do, with regard to pics
VR
Alex Olaverri
Tele: 973 204-5463
Old September 27th 2007, 10:47
That would have to be the most poorly set out website I have seen.
If you want more camber unpick your existing inner eccentric adjusters, then slot the chassis, also use MK1 Golf/Rabbit camber bolts on the struts.
Old September 27th 2007, 15:09
Steve,
I have toplines inner essentric bolts, some H&R camber bolts, haven't slotted the topline struts yet, but may need more due to the 944 spindles..
While its a bandaid, I was trying to find a way to do it easier at the track.
Alex Olaverri
Tele: 973 204-5463
Old September 27th 2007, 20:49
You could always cut the lower control arm and put a threaded section in it or make new lower control arms out of molly the correct length.
Old September 27th 2007, 21:05
Jeza Jeza is offline
Or move your strut top mounts inboard, which is effectively what you are doing. Do you need to have it adjustable though? You could set up the top at a decent amount and then dial it in or out with the chassis and strut leg adjustments.
1302 RAt "GermanLook"
Old October 22nd 2007, 21:32
vw1303's Avatar
vw1303 vw1303 is offline
Voila!
I custom made these a while ago. If I were to do them again I would buy some cheap ebay civic ones and re drill and re shape the top plates to fit the beetle.
These work great with 944 spindles. I get actually get negative camber!
Old October 22nd 2007, 22:22
Those look nice..
Did you use some alum and cut and drilled them to fit? Where they completely from scratch..
Any more pics, looks nice.
BTW, nice bars and car.
VR
Alex Olaverri
Tele: 973 204-5463
Old October 22nd 2007, 22:42
vw1303's Avatar
Yes. I turned all the bars on the lathe and tapped them. Everything you see in aluminum is made from scratch. I'm going to take the body off this week to see if it is strong enough to hold up the suspension.
