Old October 7th 2007, 04:50
judgie's Avatar
judgie judgie is offline
this is how i set mine up, but would not recomend it for the road. very unstable and twitchy.
have a 21mm anti roll bar up front and a 19mm on the rear.
7x15 front and 8x15 rear
front
runiing 45mm ground clearance at the front
130lb spring
toe 1* toe out
camber -3*
caster stock
rear
toe 1* toe out
camber -2*
lowered one spline and adjusted on the 944 spring plates
will be changing this as have gone wider on the rims and need to control the camber a bit better with the wider tryes.
cheers rob
