Porsche 915 or 930 gearbox in my 1302s
Hello
I am bilding a vw 1302s road racer. And I nead a new gearbox. And I nead to get the engin asfar as posibel in to the car. I do not whant to cut the irs tube. Mye engine is a mitsubishi 3000gt vr4 twin turbo. What is the best gearbox for my setup. 915 from 911 3,2(oil cooler) or the 930 4 speed turbo box. The engine has 320 hp and 475nm. Do some of you have god foto`s of 930 4 speed gearbox in vw. Help me decide. ![]() |
Go for the 4-speed if you can find it and if its ok with only 4 gears.
How much does that engine weigh? 200kg? it has got a cast iron block right? What about weight and balance in the car? And how are you going to get it approved in norway? Hope you get it to work together! |
The engine is not that hevy. It`s 25kg more the my t-4 turbo engine. And it`s just 6 cm longer.
one more
The engine. No gearbox is in the car.
sounds a
Intriguing conversion you have there! Unfortunately both those gearboxes will push the engine further back than standard without cutting the torsion bar housing, whatever you do...
http://www.ricola.co.uk |
It`s one of a cind. Cobramotors edition
Are those motors FWD, could you fit it east - west and use the Mitsubishi transmission like Volkdent did? http://www.germanlook.com/Forums/showthread.php?t=4697 If you mount it all behind the torsion bar housing with a suitable Porsche transmission your going to spend a lot of time driving around on your back wheels. Steve
Steve C. tanks
No worries, its hard to see every page on this site when contemplating an idea. When I saw Volkdents build-up I was very impressed with the idea of running and eats west motor in the back of bug. I guess like Volkdent you could use some of the Mitsubishi suspension. Steve
The misubishi 3000gt suspension is to big. Mabe a mitsubishi carisma or a galant suspension.
Thread Tools | |
Display Modes | |
