Old April 22nd 2008, 15:35
Hugo, how bad did the bump steer turn out?
I'm worried that it's not good because the outer pivots on your steering rack are so far outboard of the lower control arm pivot points.
Old April 23rd 2008, 10:13
hugovw1976's Avatar
hugovw1976 hugovw1976 is offline
0.013" at full droop
Actully I have to make longer the steering rack (6"). Because with the shorter rack the bumb turn in so bad.
VW 1976
Old April 23rd 2008, 21:57
Oh good!!! Longer is easier, shorter is not, so that's good. I think you must have a much better concept of suspension geometry than I do, I think I would need a lot of help building a suspension from scratch as you have. Keep us posted.
Old April 24th 2008, 10:15
hugovw1976's Avatar
The length also depend in the position of the tie rod on spindle, in the case of the Corvette C4 spindle the position is far away of the imaginary line between uper and lower ball joint.
I hope this illustration help to explain.
VW 1976
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
