Old July 15th 2008, 01:55
greenterbo's Avatar
greenterbo greenterbo is offline
Momo Install Help Needed
I am installing a Momo steering wheel and hub adapter on my 1971 Super. Has anyone done this? How did you wire up the horn?
Old July 15th 2008, 08:46
Joel's Avatar
Joel Joel is offline
i got one in mine
horn connection is same as all other wheels
boss has a copper contact at the base and a wire goes from it upto the horn button
horn button grounds out on the boss itself
Old July 15th 2008, 18:57
greenterbo's Avatar
How did you attach it? Did you add a clip or connector or solder it? Don't mean to sound dumb, though I probably am. I just want to make sure I don't run into problems later.
Old July 16th 2008, 02:02
greenterbo's Avatar
Progress!
I figured it out that I had to remove the ring from the back side of the original steering wheel! Now it is installed!
