Old September 10th 2008, 03:45
Clatter Clatter is offline
Question 944 Rear Suspension Removal
Hi All,
I'm about to make an assault on a poor hapless 944 carcass at the local U-Pull-It junkyard...
Specifically, the torsion bars and spring plates.
Looking up under the car, the 944 is kind of wierd.
THe end-caps on the torsion housing don't look like they just "come off".
Or do they?
Do you have to drop the whole housing in order to get the end-caps off, and bars out?
Putting together the tools to get everything in one shot,
What would be needed, and what to watch out for?
Old September 10th 2008, 06:08
Xellex's Avatar
Xellex Xellex is offline
why only the torsion bars and spring plates? Do you already have the trailing arms, the rotors, the brake parts, the stabilizer bar etc etc?
If you want to get everything in one shot, then get the full torsion housing, complete with everything on it, and dissasemble it at home. You will realise the actual housing is the ONLY thing you will not use on the bug.
http://www.germanlook.com/Forums/showthread.php?t=9686
Old September 10th 2008, 10:52
evilC's Avatar
evilC evilC is offline
I wholeheartedly second that! That's what I used.
evilC
Old September 10th 2008, 16:34
Yes.
just decided to do the spring plates and bars, too..
Do you have to drop the torsion housing to get the end caps off, bars/plates out?
That means i'll have to bring a jack, and this yard dont allow no jacks, so that means bring a helper.....
Old September 11th 2008, 03:14
Just unbolt the whole unit and take it home. Does have steel trailing arms or alloy?
Old September 23rd 2008, 00:34
This one has the steel arms.
I got the 4-pot brake setup plus the early mounts for the rear already.
Was going to go and drop the housing to scavenge...
It all just drops out once the visible bolts are loosened?
Are there any hidden inside the car, say under the back seat???
Would it be too gnarly for one guy to do if he's not allowed to use a jack ??
