Old June 5th 2009, 16:29
tom'72's Avatar
tom'72 tom'72 is offline
help with installing 944 MC
I have a Porsche 944 (from Kerscher) installed on my bug chassis.
In a few days Ill be mounting the pedals on the chassis and now I'm asking for some tips on how to adjust the threaded pin that goes from the brake pedal into the MC.
All I know is there should be about 1mm clearance between the MC and the threaded pin and that the pin itself needs some adjusting.
All input is welcome...
Old June 5th 2009, 16:42
Just set it up like you would a stock one. Nothing to it. I hate play, so I usually leave the 1 mm alone and install it so it just rotates easy like you do with steel pushrods
Old June 13th 2009, 15:24
tom'72's Avatar
Gave it a try today and I have a question.
Can the pin push the MC in to far ( causing damage maybe)?
If so, is there a way to determine how far in the pin should go at its furthest.
Old January 14th 2010, 14:37
jmd's Avatar
jmd jmd is offline
I would also like to know a bit more about this as I too am about to hang my pedals. I am adapting my suby pedals (hanging style) and will be using the 944T MC with the suby brake pedal Browse these images to see how it compares with the bug pedal set. would like to know if there is anything I need to do to make sure that the MC works correctly. I have a balancer that I will be fitting, so that should help in the balancing of the setup... anyone have any really good install photos?
