Old June 19th 2009, 02:42
Be carefull what you read on the inetrnet, as my above 'conclusion' was wrong!
The dented part in the middle is supposed to be there....
Originally Posted by effvee View Post
Question, in replacing the syncros and sliders, was it much to it? I to have the "I'm going to mess it up frear thing" I know I will need a trans repairman to set the gear mesh for the ring and pinion when I get the GT ATB diff. How about the linkages internally, was ther much to re-set them?
The synchros itself are difficult to get off and on. Lots of force and plyer-force needed iirc. Not fun; possible yes, maybe, just..
I didn't set linkages as I didn't loosen them, but I should have resetted it. Also here: you need to know what your doing. I had to open the tranny once more because of my inexperience...
