  #16
Old November 16th 2009, 12:42
Originally Posted by evilC View Post
I like all the work but did you consider the ground clearance?
Yes, ground clearance was measured when car was still together Clive. The rear sway-bar, and header system sit about the same level. It just looks like it sits real low. The volvo mounts sat even lower than this. If I'm not happy with it when the car is put back together for final mock-up I will change it...no big deal for me (I've got a 911 crossmember to cut-up too) just trying something different. Thanks for the comment's though.
