It's good there are some crazy people like us, who dare to initiate such projects
![]() Steve and Jason, their projects have given me many good ideas and tips. ThanksIn the front i have 1303 past 74 suspension. kw coilovers, Kerscher Anti-Roll Bar front 23mm. And rally welded front/tubeframe. I'm using the old 1302s steering box. And of course, complete set of polyurethane brusings. In the rear: According to the plan I use everything from mitsubishi front suspension. Subframe, brakes + +. But shock absorbers should I replace whit tein or Öhlins. Due to need adjustment possibilities. I also need to modify the damper, for they have come closer together at the top. Subframe the gto is very good to mount. Since it is screwed together as a unit. With two bolts in front and six on the rear. It is then bolted right in tubeframen. It seems very easy to put it on the lingering with the rest of the car. In the rear ving: I have intercooler and oil cooler.
It is not easy to get a building like this approved in Norway. It is best to travel to the tuv in Germany. Since they are the main vehicle approved in Europe.
Photo 1. subfram (from the web) Photo 2. Wing Photo 3. Porsche 944 na dics vs porsche 996 turbo c4 disc ![]() Photo 4 and 5 Some good ideas |
Div pictures of reinforcement of the frame and welding of mitsubishi frame into the vw. I decided, and spend some more of gto frontcut. So I also use parts of the front frame with motor mounts. So roll cage will be attached in it too. More updates coming soon :-)
Now is the framework from gto. Welded into the car. And I have started to attach the roll cage to the frame from the gto. Has some work left with, and make parties to the shock absorbers. + + + And some reinforcements.
Test fitting the engine and gearbox.
Lookin good, I wanna see that thing running!
| Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
